15 to 16 inch
Old October 22nd, 2012, 01:09 PM
bulldog's Avatar
15 to 16 inch
My 1999 Alero, has 15 inch tires on it. I can buy a set of 16 inch rims a tires from a 2002 Alero. Can I use these, if so will it hurt or change anything, such as the speedo ?
bulldog is offline
Old October 22nd, 2012, 01:41 PM
Lansing built
1970cs's Avatar
Your original tires size is P215-60-15, going to the optional 16" wheel should give a factory size P225-50-16 which will put you about .300 smaller in rolling diameter,it should not change your speedo to much, just slightly fast reading, also it should slightly handle better and give it a wider stance looking at it.
Just for reference front view of my Alero GLS (16" factory)
1970cs is offline
Old October 26th, 2012, 06:49 AM
As noted, the diameter of the WHEEL is irrelevant. It's the rolling radius of the TIRE that matters. Keep that the same (or close as described above) and the car will never know the difference.
joe_padavano is offline
Old October 26th, 2012, 10:31 AM
Lansing built
1970cs's Avatar
16 inchers, which ones painted GL2 or polished GLS?
To satisfy my curiosity.
Pat
1970cs is offline
Old October 31st, 2012, 06:23 AM
bulldog's Avatar
Pat
polished. I bought the 4 of them with tires that have less then 5000 km on them for $250, which I thought to be a good deal.
bulldog is offline
Old October 31st, 2012, 08:12 AM
Lansing built
1970cs's Avatar
Sounds like a great deal to me! Given that 50,000 mi tire would be around $140.00 installed.
Those rims should look like these.
Pat
1970cs is offline
Old November 1st, 2012, 05:39 AM
bulldog's Avatar
Given my poor eye sight and the size of the picture you posted, I'd say that they definatly look the same. But I'm only basing that on the raised center cap.
bulldog is offline
dz442
September 6th, 2019 03:55 PM
timothypaul
April 17th, 2013 08:35 AM
mcutlass1969
Drivetrain/Differentials
March 6th, 2008 10:24 AM
shaks 442 clone
April 25th, 2007 08:53 AM
Quick Reply: 15 to 16 inch
