'68 Cutlass Electric Power Trunk
Old October 29th, 2010, 08:05 PM
STOP call'n it a Chevelle
arodenhiser's Avatar
I know that a '68 could have had a vacuum power trunk release. I see this type of electric latch on eBay all the time. Will this bolt in place of the standard manual trunk latch without any mods to the trunk lid?
Thanks,
Adam
arodenhiser is offline
Old October 31st, 2010, 07:10 AM
stevengerard's Avatar
I do not know for sure but I would think the electric trunk release works for a lot of years from 68 - 70 something. Hopefully someone with a 68 will chime in. though on 2nd look that doesn't look like the one in my 70
stevengerard is offline
Old October 31st, 2010, 07:51 AM
I though that too 68-72 always seems to be the magic years. I guess my concern is my latch is this one. It uses three bolts. Since the latches in the two pics are upsidedown to each other I am concerned that the bolt patterns are not the same.
I might get one and try my luck.
Adam
Old November 2nd, 2010, 03:01 AM
Yellowstatue's Avatar
An electric latch from '70--'72 will fit '68...I also put a '70 latch into a '64 Chebby SS... no mods...
Yellowstatue is offline
Old November 9th, 2010, 11:12 AM
I got one of the power trunk releases I pictured above. It was almost a direct fit. The slot in my trunk lid had to be "expanded" anout 1/16" for half its width to allow the solenoid part (where you can see the part numbers) to slide in. It bolts in with only two bolts instead of three. I mocked up the wires quickly with a switch and it works perfectly. A very nice upgrade for under $30 parts and supplies.
Adam
W-27
November 29th, 2013 06:13 PM
Greg Rogers
April 11th, 2013 07:41 AM
w31man
February 9th, 2013 07:08 PM
Lady72nRob71
June 25th, 2012 11:14 AM
STRETCH1
Body work
January 30th, 2010 05:47 PM
Quick Reply: '68 Cutlass Electric Power Trunk
