Go Back   ClassicOldsmobile.com > Repair & Restoration > Electrical
Forums Gallery Encyclopedia Tech Olds Junction Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Thread Tools Display Modes
Old 05-16-2008, 07:50 AM   #1 (permalink)
cisco88
Junior Member
Altenator bracket
Hey there, I am not sure if this would be the correct place to put this thread. Without it I would have to power going thru the veh.
I have a 1955 oldsmobile 88 with a 394 ci from a 61 and have alt bracket from a 63 that bolted right up. The problem that I am having is that the bracket for the altenator does not line up the alt correctly and belt comes out crook it. Not only that, if any one is familiar with that bracket it is a big hunk of metal. Would like to clean it up some.
Does anyone know if anybody make alt brakets for the alt, or if another veh has a much simplar bracket that will fit this engine?
cisco88 is offline   Reply With Quote
Old 05-16-2008, 06:20 PM   #2 (permalink)
jeffrey
Rocketeer Jr.
OK, You can shave/ shim the bracket at the base and the alternator mount points until it looks like Godzilla's asshole, and it will work.
Or (better) fab a custom bracket.
Years ago (when times were tough) I cut one in half horizontally, mounted it at the bottom, bolted a dog chain to the top, then bolted the other end of the chain to the firewall and adjusted the pitch of the alternator by tightening/loosening the firewall bolt. It worked for years.
Good Luck,
Jeff
__________________
'53 Olds 88
'55 98
'56 Holiday 88
'56 S-88 Conv
'70 Cutlass SX
jeffrey is offline   Reply With Quote
Old 05-16-2008, 09:01 PM   #3 (permalink)
59-59-59
Senior Member
Are you using a universal aftermarket alternator? Exactly what bracket are you talking about? Is it the bracket that holds the alternator in place or is it the 'arm' where you can adjust the tension? If it is the lower bracket that holds the alternator in place, maybe you can enlarge the bolt holes to be oblong so you can slide the alternator back or fourth so the belts line up. If your looking for a newer bracket, I have used just a universal chevy alternator mount with a universal 1 wire alternator. Some easy fabrication was needed
59-59-59 is offline   Reply With Quote
Old 05-27-2008, 03:12 PM   #4 (permalink)
justinj
Junior Member
Quote:
Hi there. I bought a "universal alternator bracket" from ebay for my 394. He is selling more of them - item number 250249790380. It's $20. Not the best looking thing in the world, but it is designed for generator replacements. Works for me.
-justinj
justinj is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Altenator brackets 63 or 64 pics cisco88 ClassicOldsmobile General Discussion 0 03-26-2008 05:01 AM
8.5'' Rear yoke bracket J-(Chicago) Parts Wanted 0 03-08-2008 05:32 PM
63', 64' altenator bracket 394 ci cisco88 Parts Wanted 0 02-29-2008 01:32 PM
62, 63, 64, Alternator Bracket Natas Parts Wanted 1 11-24-2007 06:07 PM
Alternator Bracket 394 Natas Parts Wanted 0 11-15-2007 05:42 PM
Powered by vBulletin® Version 3.6.8
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.0.0
All content Copyright © 2008 by Internet Brands, Inc.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34
