oil restrictors with high volume oil pump.
Old February 16th, 2010, 07:05 AM
86pontiac's Avatar
I am building a 1977 403, and I have read online a couple of times that when you put a high volume pump, or it may happen even with the standard volume, that all the oil in olds engines tends to run to the top of the motor and starves the bottom end. What do yall think about this topic and since the engine is not going to be used at the strip, strictly daily driver, should I use the oil resticors?
86pontiac is offline
Old February 16th, 2010, 07:15 AM
cutlassefi's Avatar
First question I would ask is what type of mods? Then if it's only going to be a mild daily driver why are you putting in a High Volume pump? For that application you don't need it IMO.
cutlassefi is offline
Old February 16th, 2010, 07:38 AM
86pontiac's Avatar
http://www.summitracing.com/checkout/cart.aspx
This is the list of all my mods. Well I have built one engine fo rmy ford truck,a nd been help of building anouther and on both of them we used high voume pumps just for the simple fact of better oil circulation.
Old February 16th, 2010, 07:41 AM
86pontiac's Avatar
Oh and I am going to port and polish the original heads.
Old February 16th, 2010, 09:03 AM
I put a HV oil pump in my Olds for the same reason (simply to have it). However, I put in a Milodon deep sump pan as well. I wouldn't run a HV oil pump without a deep sump pan.
Olds64 is offline
Old February 16th, 2010, 10:12 AM
cutlassefi's Avatar
86pontiac your cart was empty.
I'm with olds64. At least the 5 qt from Milodon would be good. My first build was a stock pan with restrictors on a mild motor with a HV pump. Didn't need it, won't do it again.
Old February 16th, 2010, 10:40 AM
86pontiac's Avatar
I just clicked on the link and it had everything that I clicked to put in the cart.
Old February 16th, 2010, 10:50 AM
86pontiac's Avatar
So you didnt need the restricors after all.
Old February 16th, 2010, 10:53 AM
You might want to read through this thread:
https://classicoldsmobile.com/forums...strictors.html
joe_padavano is offline
Old February 16th, 2010, 11:46 AM
86pontiac's Avatar
Ok, so, what I have read is that unless you are running an engine at upwards of 5000 rpm, or high horsepower racing, then there is no need for oil restrictors. So therefore I could run a high volume pump, to ensure qaulity oiling, and a 5qt pan so I dont suck it dry. Anybody who doesnt think this is good please tell me otherwise.
Old February 16th, 2010, 12:10 PM
I wouldn't run a HV oil pump without the deep sump pan. The Milodon and Moroso deep sump pans are 7 quart. IMHO the Milodon is worth the extra $30.
Olds64 is offline
Old February 16th, 2010, 01:04 PM
My442's Avatar
Milodon 7 quart pan, HV oil pump, windage tray here.
No restrictors.
My442 is offline
Old February 16th, 2010, 01:42 PM
380 Racer's Avatar
Raced for quite a few years.......stock pan, HV pump and restrictors.
380 Racer is offline
Old February 16th, 2010, 02:04 PM
cutlassefi's Avatar
You're not really going to use that hydraulic roller for a daily driver are you?
Old February 16th, 2010, 07:10 PM
86pontiac's Avatar
If you mean the cam, then yes, and it is a hydraulic flat tappet.
Old February 17th, 2010, 07:22 AM
cutlassefi's Avatar
If it's the one I'm looking at it says Hydraulic roller for a Pontiac. Maybe I'm mistake but that's what shows up when I click on the link. The picture is a flat tappet but the description is for a roller. It better be for $739.95!
Old February 17th, 2010, 11:24 AM
captjim's Avatar
Just my opinion but if you are running stock (snug) bearing clearances then the stock pump will be more than adequate, Just check pan to pickup clearance and having the pickup tacked in place is cheap insurance.
captjim is offline
davebw31
July 14th, 2013 05:02 PM
Sampson
April 4th, 2013 09:47 AM
Redog
October 8th, 2010 02:57 PM
68conv455
December 26th, 2007 07:29 AM
Joel n
January 12th, 2007 03:34 PM
Quick Reply: oil restrictors with high volume oil pump.
