Do tubular control arms make for a bumpier ride?
Old December 10th, 2023, 02:17 PM
James J's Avatar
Hey Guys, I love the handling of newer cars like my 2000 Accord. I got some rear boxed aftermarket control arms at the swap meet. But what I was wondering about is if fronts would ruin the smooth ride of the old American cars, poly bushings and such. 84 cutlass H/O. Thanks Jackson
James J is offline
Old December 10th, 2023, 02:33 PM
I would think that the polyurethane bushings would have more of an effect on ride quality than the tubular control arms. Then again, if your Oldsmobile has OE control arm bushings in it now, even polyurethane bushings would be an improvement.
Olds64 is online now
Old December 10th, 2023, 02:40 PM
Jesse is correct. The bushings are the determining factor for ride quality. Urethane bushings (no matter which arms you use) will give a stiffer ride since they are less compliant than rubber bushings.
joe_padavano is offline
Old December 10th, 2023, 02:46 PM
Most people replace the worn rubber bushings and find that the car rides better even with the poly ones installed.
oldcutlass is online now
Old December 10th, 2023, 04:37 PM
72Cutlass S
gs72's Avatar
If you do switch to poly bushings buy a tub of the grease/paste the manufacturer recommends for assembly. The amount they give you with the kit is not enough. If you don't grease the crap out of them on assembly they will dry out and squeak like crazy. Been there done that.
gs72 is offline
Old December 10th, 2023, 05:11 PM
^x2^ I had a tub of the lube paste available when I changed mine out.
Vintage Chief is online now
Old December 10th, 2023, 07:45 PM
bccan's Avatar
I’m a fan of the bearing style bushings, such as Global West’s Del-A-Lum. Smoooth and a great ride..
bccan is offline
Rob64cutlass
Suspension & Handling
22
November 19th, 2023 07:07 PM
jonnyslim63
September 30th, 2021 09:33 AM
cbartonbrown
October 7th, 2019 08:26 AM
76olds
October 5th, 2014 08:36 AM
oldzy
December 5th, 2010 11:48 AM
Quick Reply: Do tubular control arms make for a bumpier ride?
