“Ninety Eight” script removal by rear bumper on ‘72
Old October 17th, 2023, 05:24 PM
jpilk99's Avatar
I’m doing a little work on rust spots on rear quarters and need to remove the “Ninety Eight” scripts. It looks like their legs are almost like rivets inside the trunk; see pics
. How should I remove so I can reinstall when done? Thanks
jpilk99 is offline
Old October 17th, 2023, 06:46 PM
Past Administrator
Oldsguy's Avatar
From my experience with similar trunk scripts they are in fact a kind of rivet. I have removed some before that were loose already and forced some out by striking the ends of them from the inside of the panel but then you run the chance of enlarging the corrseponding hole. Not sure if there is a non-destructive way to do it. Good luck.
Oldsguy is offline
Old October 17th, 2023, 06:47 PM
Oldsdruid
rocketraider's Avatar
They were originally installed with what's called a Tinnerman nut that screwed onto the mounting studs. Those look like they may have been removed before and the studs broke, and they were either glued back on or may have been installed using barrel clips.
You can try two things. First, use a small plastic hammer to see if you can tap them out from inside the trunk, or get a stiff bladed putty knife or plastic trim removal tool and see if you can pry them off from outside the car. You can get either at Harbor Freight.
*edit* Looks like someone's been in there before and there's some body filler in the panel. It may be thick enough to have caused issues remounting the script.
rocketraider is offline
Old October 18th, 2023, 02:47 AM
^^^THIS^^^
Just be careful. Try to gently tap them out with a hammer from the backside.🤞
Olds64 is offline
Old October 18th, 2023, 06:49 AM
jpilk99's Avatar
Thanks All. This car, which I love, is definitely only a "driver". It has PLENTY of blemishes. I'll do my best not to add to those blemishes. Just want to slow the progression of rust. Thanks again!!!
jpilk99 is offline
Old October 19th, 2023, 12:46 PM
jpilk99's Avatar
Update: I was able to remove the scripts. I wire brushed the stems and then took a wood-handled tool and "butt"ed them out. All good. Thanks all.
jpilk99 is offline
Old October 19th, 2023, 01:04 PM
Glad they didn't get damaged during removal.👍
Olds64 is offline
Old October 20th, 2023, 05:39 AM
Past Administrator
Oldsguy's Avatar
Good to hear it.
Oldsguy is offline
Platinum Al
December 21st, 2017 05:55 PM
KDW
August 26th, 2016 07:46 PM
Alex72cutty
July 26th, 2012 01:56 AM
Thomas Simcich
Body work
October 20th, 2011 10:24 AM
cmarshall
November 13th, 2009 04:50 PM
Quick Reply: “Ninety Eight” script removal by rear bumper on ‘72
