330/350 Flexplate
Old April 5th, 2024, 02:02 PM
DB Cooper's Avatar
330/350 Flexplate
I’m considering installing a 350TH from a 1973 Cutlass into my 1965 Cutlass. Both cars are original. The 65 is equipped with the Jetaway transmission. I understand that its a pretty straightforward swap other than the shift linkage issue. I know that the crankshaft flange is different on a 65 330 than the cast crank 73 350. My question is, will the torque converter of the 350TH bolt to the flexplate of the 330?
I hope this make sense!
DB Cooper is offline
Old April 5th, 2024, 02:30 PM
The converter bolt pattern will be the same. You can’t use the 350 FLEXPLATE on the 330, the bolt pattern is different.
To answer your question: the TH350 converter will work on the 330 engine.
matt69olds is offline
Old April 5th, 2024, 02:53 PM
DB Cooper's Avatar
Thank you! Just wanted to get my facts straight while I contemplate my next move.
NTXOlds
March 26th, 2023 06:31 AM
jjpape
August 11th, 2015 05:09 PM
Olds442redberet
December 31st, 2013 06:40 PM
import extermination
April 26th, 2010 01:16 PM
78cutlass
March 27th, 2008 04:46 AM
Quick Reply: 330/350 Flexplate
