70 cutlass supreme convertible my first frame off
Old January 11th, 2021, 07:46 AM
  #81
72 Olds CS
RetroRanger's Avatar
Nice job fabbing up that piece.
iirc scrappie removed that entire top part in his resto thread if you want to get a look at how it is under that panel
RetroRanger is offline
Old January 12th, 2021, 06:29 PM
  #82
tkcutlass's Avatar
Got the inner patch installed still a bunch of pinholes I keep blowing through some of holes making them worse.
went back with a copper backing got the large holes filled not sure if it's worth trying to patch those little holes.. I made a bunch of little holes into large ones.
tkcutlass is online now
Old January 13th, 2021, 09:56 PM
  #83
tkcutlass's Avatar
My buddy Mike the madman went to town drilling out spot welds and we got the under rear seat pulled out.
Old January 14th, 2021, 06:16 PM
  #84
tkcutlass's Avatar
Back to working on the cowl.
Patched a few pinholes primed it up with weldable primer, and got the outer patch close to ready to weld in place.
Old January 17th, 2021, 05:24 PM
  #85
tkcutlass's Avatar
The patch is in, a little more tweaking and grinding but could be worse.
Old January 21st, 2021, 08:43 PM
  #86
tkcutlass's Avatar
Decided to take a shot at filling some holes on the windshield frame.
A lot of patience and grinding I managed to fill a couple holes
Found a better way, make a little patch, shape and hold it with a coat hanger
Getting ready for the next one
Old January 21st, 2021, 08:54 PM
  #87
Nice great hard work. 👍
no1oldsfan is offline
Old January 22nd, 2021, 05:51 AM
  #88
Mr Gadgets's Avatar
Nice Work!!
Mr Gadgets is offline
Old January 24th, 2021, 08:48 PM
  #89
tkcutlass's Avatar
Got a few more patches in, with all this practice my horrible welds are slowly ...(very slowly) getting better.
Plenty more to practice on
Old January 24th, 2021, 09:14 PM
  #90
woodie582's Avatar
Have you thought about replacing that header?
woodie582 is online now
Old January 24th, 2021, 09:44 PM
  #91
tkcutlass's Avatar
I wasn't aware just the top windshield header was available and wouldn't that be very difficult to get it aligned perfectly?
Old January 25th, 2021, 10:03 PM
  #92
tkcutlass's Avatar
The last patch on the cowl is done, well at least up top.
the tipping wheel makes it easy to do curved bends.
Old January 26th, 2021, 10:25 AM
  #93
Mr Gadgets's Avatar
Looks good.. The welding is coming along.. The other day I tried a change on the settings on the mig. I turned the heat down and slowed the wire feed down.. I was shocked at how nicely the weld came out. I was actually able to control the puddle better that way. Give it a try and see what happens..
I hope it helps!
Old January 30th, 2021, 09:00 PM
  #94
tkcutlass's Avatar
Started patching the wheel wells.
Started with a big patch making it easier to form
ended up with just a small portion of the original patch
I left the edge of cut piece attached to help with aligning the contour of the patch
welded the inside edge
Filled a couple holes on the other side
Old February 3rd, 2021, 09:22 PM
  #95
tkcutlass's Avatar
Started fitting the back seat floor patch.
Going to try and slip it under the spot welds.
Tips anyone?
Old February 14th, 2021, 07:27 PM
  #96
tkcutlass's Avatar
We managed to get the patch tucked between the brace and the old floor and peeled back the side.
Not sure if that's the right way but should be a lot stronger than a butt weld. (Is this overkill?)
Old February 14th, 2021, 09:00 PM
  #97
tkcutlass's Avatar
Started welding up the seams on the previously installed floor pan
Old February 14th, 2021, 09:15 PM
  #98
tkcutlass's Avatar
Moved on to the trunk area to patch the inner wheel well.
Ran out of welding gas so moved on to prepping the other side
Old February 14th, 2021, 09:31 PM
  #99
tkcutlass's Avatar
Started fitting the trunk pan.
Drilled the spot welds for the seat divider to slip the floor in between.
Old February 15th, 2021, 09:53 AM
  #100
Mr Gadgets's Avatar
It's coming along nicely!! Keep up the good work!!
Old February 15th, 2021, 06:07 PM
  #101
tkcutlass's Avatar
Got an hour to sneak out to the garage more welds on the floor pan.
Got an 80 cf tank so I don't run out every time I turn around.
Turned up the gas flow a bit and I think my welds are finally coming around.
Old February 25th, 2021, 08:35 PM
  #102
tkcutlass's Avatar
Finished welding up the main floor​​​​​​​
Old February 25th, 2021, 08:45 PM
  #103
tkcutlass's Avatar
Noticed the front body mount was shifting when rotating the frame.
welded the inner brace and made a 16 gage patch.
Old February 26th, 2021, 12:41 PM
  #104
Mr Gadgets's Avatar
Coming along nicely!! Keep up the good work!
Old February 28th, 2021, 07:48 PM
  #105
tkcutlass's Avatar
I figured I'd check the other mount while I had everything setup.
It looked good but after deeper examination, it was actually worse than the other side.
Old March 1st, 2021, 06:35 PM
  #106
Some call me, Tim
Tim75's Avatar
This is an impressive build!
Tim75 is offline
Old March 1st, 2021, 08:46 PM
  #107
tkcutlass's Avatar
Thanks, Tim
It has been fun and challenging.
Old March 1st, 2021, 08:57 PM
  #108
tkcutlass's Avatar
Been practicing with my new English wheel amazing how even a rookie like me can create halfway decent results.
Old March 2nd, 2021, 09:52 PM
  #109
tkcutlass's Avatar
Waiting for the 18 gauge I moved on to repairing the floor brace.
Going to wait for the nice weather tomorrow so I can open the doors and put a fan on while welding the galvanized area
Old March 3rd, 2021, 05:21 PM
  #110
tkcutlass's Avatar
Welded up the brace
Old March 7th, 2021, 07:21 PM
  #111
tkcutlass's Avatar
Next up outer wheel well patch
Old March 16th, 2021, 10:25 PM
  #112
tkcutlass's Avatar
The quarter patch has many contours and was tricky but I am pretty happy with how it turned out.
Needs a little fine-tuning but getting there.
Old April 11th, 2021, 06:43 PM
  #113
tkcutlass's Avatar
Spent some time cleaning up all the misc parts laying around and got them stored used my body cart to move old red to the lower garage.
Old April 16th, 2021, 08:56 PM
  #114
tkcutlass's Avatar
Been busy... going to try and catch up.
Got a bunch of parts a GTO was getting upgraded to a Ford 9 inch with a Tremec 5 speed so I got a good deal on recently removed parts. With about 50 miles on them.
3.55 posi
Old April 16th, 2021, 09:19 PM
  #115
tkcutlass's Avatar
Started filling in the windshield frame and front cowl.
Old April 16th, 2021, 09:29 PM
  #116
tkcutlass's Avatar
Prepped and painted the Upper control arms that I just picked up.
Added new bushings while at it. (They came with new ball joints)
Old April 16th, 2021, 09:49 PM
  #117
tkcutlass's Avatar
Thanks to Trophyblue442 I got a rear cross member and with luck, I can get that and the trunk welded in.
Got most of the spot welds drilled out.
Old April 17th, 2021, 07:43 AM
  #118
Nice. Progress is progress. Keep at it.
Old April 17th, 2021, 11:25 AM
  #119
Phoenix8990's Avatar
WOW, you are doing a lot of amazing work. I would suggest playing with the amperage and wire speed. It should run a nice continuous bead, sounding like bacon crackling. It looks like it's sputtering, either a little less wire speed or a bit more amperage. I'm happy to see you found this car to work on, the rust bucket would have been a crazy amount of work. Looking forward to seeing your progress!!!
Steve
Phoenix8990 is offline
Old April 17th, 2021, 01:19 PM
  #120
tkcutlass's Avatar
Steve
Thanks for the kind words. I can always use tips... especially on welding.
I still have old red and acquired almost everything I need to make two.
This one is turning out to be a 1000 piece puzzle, the other might be easier by replacing a small number of large pieces vs all the small pieces as I am doing with this one
Quick Reply: 70 cutlass supreme convertible my first frame off
