Kickdown and Switch Pitch Solenoid removal and manual replacement in ST-300 Jetaway
Old May 9th, 2024, 08:04 PM
TheBagle's Avatar
I have recently replaced my intake manifold, and carburetor on my 1964 Cutlass, and when replacing the transmission filter I noticed the electric kick down cable wire in there and realized that I won’t have a kickdown anymore. Is there anyway to remove the electric one and replace it with a manual kick down. And if so which cable and brackets would I need.
TheBagle is offline
Old May 9th, 2024, 09:54 PM
You need an electric switch that’s activated by the throttle position. The later TH400 cars had this on the pedal assembly.
Fun71 is offline
Old May 10th, 2024, 01:25 AM
A "manual" kickdown option is when you move the shift lever from D to L. Otherwise, install the switch so it works correctly.
joe_padavano is offline
lala5818
October 29th, 2022 08:55 AM
69CutlassAlex
September 19th, 2022 04:50 PM
Moegs
July 15th, 2022 05:01 PM
Stevec
June 7th, 2012 01:13 PM
bigbrother
17
March 11th, 2012 06:45 PM
Quick Reply: Kickdown and Switch Pitch Solenoid removal and manual replacement in ST-300 Jetaway
