Click Here
15x7 said trim rings
Old March 6th, 2024, 06:06 PM
Mu37strd's Avatar
15x7 ssii trim rings
I just picked up a set of what I believe to be mid 70s 15x7 ssii wheels. The trim rings are fairly beat up so I am looking for replacements. Does anybody currently know of a good source for replacements. I tried searching but most of the threads I have found were older. The best looking/priced ones I have found are from opgi but I have heard bad things about that company. Thanks
Mu37strd is offline
Old March 13th, 2024, 01:27 AM
MOTORHEAD
11971four4two's Avatar
I found a source for 15x7 DEEP trim rings that fit the 15 x 7 Olds rally wheels. These DO have a different "profile" on the outer inch at the outer edge than what the original had. They are stainless steel that is triple chrome plated. $175 set of 4 located near minneapolis mn
11971four4two is offline
Old March 13th, 2024, 05:22 PM
old80cs's Avatar
Speedway Motors sells replacement trim rings.
old80cs is offline
Old March 14th, 2024, 03:04 PM
Freestate's Avatar
I just bought a set of 15" "Rally Wheel" rings in the 3" depth from The Parts Place. Despite the website's claim that they fit 1975 Olds 15" wheels, they do NOT fit. The diameter of the inner part of the ring is about 12 1/2", whereas the stock rings are 11 5/8".
OEM rings
The Parts Place 3" deep
edge comparison
Freestate is offline
Old March 14th, 2024, 05:00 PM
I'm sure those rings fit Chevy Rally wheels just fine. Once again, the problem with the 15" SuperStock wheels is that they use the same stamped centers as do the 14" wheels. The hoops on the 15" SS II/III wheels are unique to these wheels because they neck down to that smaller center disk. This is also why it is so difficult to find aftermarket hoops to make wider SuperStock wheels.
joe_padavano is offline
Old March 14th, 2024, 06:17 PM
MOTORHEAD
About 11 5/8 on the inside and 28 3/4 outside is what I have
Old March 14th, 2024, 07:43 PM
4speed455's Avatar
Those look like the ones I’m using. Although they are not the same as originals they do fit and look nice.
4speed455 is online now
Old March 14th, 2024, 08:04 PM
CH3NO2 LEARN IT BURN IT
droldsmorland's Avatar
How beat up are your trim rings. Theres a guy that advertises in NCRS driveline that restores trim rings to NCRS standards.
I can dig out his contact if you want it?
Prob not cheap.
droldsmorland is offline
Old March 20th, 2024, 08:45 AM
Mu37strd's Avatar
Do you know where you got your rings? They look close enough for me. I still have the factory 14” setup in perfect condition so I’m just looking for driver quality good enough.
Mu37strd is offline
Old March 20th, 2024, 12:57 PM
4speed455's Avatar
I got them on eBay.
https://www.ebay.com/itm/13429766950...Bk9SR9DG6f_IYw
PaulWinn
Wheels and Tires
December 13th, 2022 10:15 AM
rr69ho
January 31st, 2022 01:32 PM
Koda
Wheels and Tires
May 6th, 2021 10:14 AM
Cruzinbill
August 28th, 2019 10:50 AM
rarerallye350
May 21st, 2019 05:26 PM
Quick Reply: 15x7 said trim rings
