17" superstock 2 wheels
#43
Added info
They are right around 26" tall when I put them next to my 225/70 14's they are the same height
#49
Thanks.
#51
No, no photos or measurements available for you. Template showed they should fit (we triple checked and even talked to Baer), but when installing the outer corners of the calipers hit the secondary lip further into the wheel. Purchased the SS4s thinking they'd be small enough clear to clear the wheels (after again checking the template dimensions) but they hit as well, just further in.
#54
@RetroRanger Thanks!
#55
17”
I just picked up a set of these om a black friday deal. Staggered 17 x 8 and 17 x 9.
I have to say that I am quite impressed. They look way better in person than in the crappy photos online at Year One.
Quality and paint look awesome. These will be going on my Rallye 350 I am restoring. I will paint at least the center area yellow.
Pat
Pat
were you able to fine white letter wheels that size?
#58
To those interested. I too had purchased those same Year One SSII wheels (staggered width front and back) in September 2019 after wanting more breaking power than a basic rear disc conversion was going to provide. Doing that meant larger wheels.
Just a heads up these are brushed/polished aluminum to look like chrome, but they also to have a chromed version. But they look great, so good in fact that I'm torn on painting them the body color (Viking Blue)...I will say that I do somewhat regret not going with 8" all around so I can run a common spare and rotate tires.
Tires - Nittos all around Front: 255/50R17, Rear: 275/50R17. I wanted side wall and some bulge to give it as close to a classic look as possible. Mine look very similar to the photos above.
Brakes - Front: Baer Brakes Track 4 front brake kit (A body, 13" rotors). Rear: Baer IronSport rear brake package. (Ironsports were cheaper than the Track4s).
Thanks,
Chris
#59
Where do they sell these ones at? I am looking at ordering the Silver SSII 17" rims this weekend from YearOne but those ones are really sweet. I like these ones you posted better for my 1972 Cutlass. Modern look to an old classic.
#60
I have a Question for the OP of this thread - Same as what was asked last, did you have fitment issues with clearing the rear tail pies as they come around the tank running that tire ? 275/45/17 ?
#61
https://www.yearone.com/Catalog/whee...super-stock-ii
These wheels from YO are only stock style 17s currently in production but they're not perfect. A higher quality wheel (primarily with design) would be able to fit the larger calipers designed for 17" wheels, as many 17" wheels can. This wheel is likely focused on fitting brakes that would typically be paired with 15" wheels. My impression is that they're geared ttowards the stock and 15" crowd that's not intent on major brake modifications. One last note, the brushed aluminum looks nice, but I do wish I would have spent the slight extra $ for the chromed to give it a more correct appearance.
Love the wheels though and get lots of compliments.
#67
I also purchased these wheels recently and am now worried I cant upgrade brakes.
Has anyone fit c5/c6 brakes with these wheels? What other options for upgrade do I have?
FYI i went 17x9 w/ 275/40r17s. Have not finished test fitting/turning wheel lock to lock.
#68
Can only give my feedback on what I have. Baer's conversion kit does fit and I'd imagine other kits like Wildwood do as well, you just can go crazy with huge calipers. I have 11" rotors with the SS4 calipers in the front and irons sports (11.25" I think) on the rear with room to spare. I'm not sure how those dimensions may compare to c5/c6. I'd guess there's dimensions posted for both that could be compared.
As a side note, make sure you have the right proportioning valve for disc brakes or buy an adjustable for better fine tuning. You'll be upping the piston bore area, so you'll also consider an appropriate master cylinder/vacuum booster combo. Ideally you'd match the percentage increase in caliper piston area to the master cylinder piston area increase to achieve a similar pedal response to the original calipers. Usually this means going to a smaller master cylinder, and depending on how crazy you go, improving your brake booster (such as a large dual diaphragm). Many people upgrade just the rotors and calipers usually with poor results, because they didn't consider the other components or do the math.
#69
#70
#71
...I am thinking I might just get some wilwood d52 calipers and better pads for now. Next step will be figuring out rear discs but the list of things to do on the car is already long enough without getting heavy into brakes. Next I need to figure out what suspension mods to lower the car more.
Rodney
#72
...The Blazer parts will require a shim behind the backing plate to center the rotor in the caliper and a wheel bearing spacer to compensate for the Blazer's thicker backing plate. Get a 2WD set-up as the 4WD parts use a deeper rotor hat that doesn't line-up well with the stock width BOP rear axle flange.
Rodney
Rodney
I hope im not hijacking the post, but i have a few questions if you could help me with.
1- I understand the shim behind the backing plate but I don't understand the wheel bearing spacer? Is it a shim placed on the axle before seal and bearing are pressed on the axle so that seal and bearing seat properly and don't come out of the diff too far? Sorry but I just can't visualize it.
2- is there an easy way to identify the 2wd rotors from the 4wd rotors?
thanks
I appreciate it, paul
#73
Blazer Rear Disc Brakes
I hope the OP doesn't feel like we've hijacked his thread; this brake info seems relevant to 17" wheel fitment and could be helpful to others who might search and find his thread.
Paul:
The blazer backing plate is comprised of a 3/8" thick aluminum plate that supports the parking brake mechanism and & caliper and a separate metal dust shield. The stock Olds drum brake backing plates are only 1/8" thick. The bearing spacer makes up for the thickness difference and fits inside the axle tube to hold the bearing and seal behind the retaining plate. Follow the link below to my build thread and look at posts #68 & #79 to see the Blazer parts I used and the placement of the shim & spacer.
Rodney
https://classicoldsmobile.com/forums...e-57404/page2/
Paul:
Rodney
#74
FYI: Early to mid 2000 era Blazers used a 11.6" rear rotor that should fit inside those 17" rims. I mocked these parts up a few years ago and it seemed like they might even fit inside some 15" SSIII factory rims. The Blazer parts will require a shim behind the backing plate to center the rotor in the caliper and a wheel bearing spacer to compensate for the Blazer's thicker backing plate. Get a 2WD set-up as the 4WD parts use a deeper rotor hat that doesn't line-up well with the stock width BOP rear axle flange. They also incorporated a drum-in-hat style parking brake that many of the performance brake kits lack. The drum-in-hat parking brake is less prone to adjustment issues than the ratchet style calipers found in some of the classic car rear disc retrofit kits.
Rodney
Rodney
2 in lower springs for rear and about to order tall 2" drop spindle. Hope it sits how I want after that.
#76
Pat
Pat
#77
17x9 with 275/40r17 square. BMR rear 2" drop spings with bilstein shocks, BMR front upper and lower a arms, g comp tall 2" drop spindle, UMI stock height springs, bilstein front shocks. Need to get cetner caps off and get it out of garage. Hope the front settles a bit.
