1971 442 w30
1971 442 w30
So I got my old High school car out from my folks place as they moved and was going to start the rebuild process on it. Its been sitting for 30+ years, I had the engine torn down and have had it stored partially together, going to bring it back to the shop that machined it and have them put it back together a good reputable race engine shop, the 4 speed is cleaned up waiting for the motor, so I can at least get it running and moving around on its own power. Then start on the body the trunk and quarters are a little rusty. The hood was restored when I took the motor out as the paint was falling off from it so it is just in primer now. I found this sheet in the back seat wish it was in better condition. Hopefully will try and update as progress is gained. I just found this site and thought it would be great for information that I might need or to ask questions.
you have come to the right place! Nice ride hopefully you post your progression here I would love to follow! What a car to have in high school love it! Looks pretty good for sitting 30+ years and especially if those are Minnesota plates I see, Welcome!
No difference between W-30 and and non W-30 carbs in 1971. Automatic and manual transmission carbs are different.
Some of the factory literature for 71 have the incorrect numbers listed. It took a while for me to find out what was correct for my 4 speed. There is not a lot of information out there for the 71s compared to 70s.
Don W
Don W
Getting closer
The motor is almost done had a cracked exhaust manifold so found a good one to replace it. Should be going to the dyno soon. Been a slow process but a good friend has been doing the motor work.
I believe it also has 2 barrel jets in the primaries. Supposedly, the 70 W30 455 manual made very poor vacuum and could not haul those rods up reliably, so they did a workaround, removed the rods, and changed the jets. I do not know what cam changes were made to it to go to 71. It did, like they all did, have less compression in 71. Since the power piston and rod assembly was back in 71, I suppose it made enough vacuum to run it in that config.
#32
2. The "vacuum" actually holds the primary metering rods down against the power piston spring pressure. Low vacuum allowed the power piston to lift and the smaller end of the metering rods to enrich the A/F mixture.
3. SMT W-30's didn't need the precise A/F as much as the W-30 Auto transmission equipped cars. The "softer" (different vacuum range) power pistons were available through the Oldsmobile dealer parts counter from Rochester. Cliff Ruggles and a few others market similar springs now.
#33
What an awesome high school car, and you had the fore thought to keep it..Very cool, keep showing the progress..I have a 70, I actually like the nose and grill on the 71 better..Kewl ride my friend
#37
Awesome !!
The factory saw 372 @ 4800 RPM, I call that mission accomplished .
https://www.motortrend.com/features/...r-1960s-1970s/
#39
70W30Jim
March 1st, 2016 12:37 AM
