'68 4-4-2 Trunk Weather Stripping
Old September 27th, 2015, 06:13 PM
ezman604's Avatar
I bought replacement weather stripping and getting ready to install it. At a car show yesterday, one of the judges pulled me aside and told me the difference between first and second place can come down to a very few points and my weather stripping could be the ticket. I told him I had purchased the materials just have not had the time to replace them yet. He also informed me to find the junction where both ends come together and make certain I use the same point. I honestly cannot find this with my factory seal. Really looks like a solid strip.
Just curious where the junction is normally located on these. That would help me find mine. I've looked very closely 4-5X already with a flashlight and lightly pressing on the seal. Junction alludes me so far.
Thanks AOT!!!
Dave
ezman604 is offline
Old September 27th, 2015, 06:31 PM
Randy C.
rcorrigan5's Avatar
My '68 was judged at the Reno OCA Nationals in 2011 and it won Best In Class with 986 points out of 1000. When I replaced my weatherstrip in2007, the break in the original was on the bottom end, right in the middle. That's where I put the break in my new one.
Hope this helps!
Randy C.
rcorrigan5 is offline
Old September 27th, 2015, 06:42 PM
ezman604's Avatar
Thanks Randy...I'll look closer there.
ezman604 is offline
Old September 28th, 2015, 02:43 PM
Yellowstatue's Avatar
And when you install the new weatherstrip, use black adhesive to glue the ends together...
Yellowstatue is offline
Old September 28th, 2015, 07:09 PM
ezman604's Avatar
Excellent tip!!!
Thanks.
ezman604 is offline
Old September 28th, 2015, 10:09 PM
Use this, Advance Auto carries it.
1969w3155 is offline
Old September 29th, 2015, 10:15 AM
CH3NO2 LEARN IT BURN IT
droldsmorland's Avatar
I dont use adhesive at all. That way I can pull it out and towel out the water that collects on the lower channel and allow the rubber to dry. Its just another thing I do to thwart off the tin worms. I cut mine slightly larger to allow for shrinkage and it holds the ends together nicely.
droldsmorland is offline
Old October 11th, 2015, 05:02 PM
briane's Avatar
When you remove the original trunk weatherstrip, take a close look at the cross-section and select a reproduction to match it as close as possible. They seem to differ between the various sources. I found one that was very good, virtually identical to the original. This is not the case for the superseded GM NOS part number that is very high priced on e-bay, it differs from the original GM part number.
briane is offline
Sully69
February 26th, 2015 08:58 AM
72cuttthang
July 23rd, 2012 02:00 PM
brent
October 3rd, 2011 07:47 AM
KRICHEN922
Body work
March 27th, 2010 11:07 AM
yzzerdd
March 8th, 2010 05:11 AM
Quick Reply: '68 4-4-2 Trunk Weather Stripping
