70 olds W-30 suspension question
Hello to all,
car has bad wheel hop,
currently car is on the stands, changed front/rear springs and shocks,
installed new rear boxed arms, my question is should i tighten the bolts on arms while car is off the ground or full weight on the ground..
any help would be appreciated..
Keep posted if that fixes your problem, I have the same problem, replaced with good shocks still hops like a rabbit..I did not loosen control arms and retighten on the ground..curious if that fixes your problem.
STATUS to bad wheel hop, all boxed lower new control arms have new bushings also changed upper arm with new bushings, tightened arms with car on ground, still hops like a rabbit..maybe different better shocks, even though they are new KYB
Looked up wheel hop on YouTube, in this video's comments section the chevelle owner replied a fix. He installed the UMI parts & fixed the problem. I've also heard adjustable upper control arms can be used to tune out wheel hop.
https://www.umiperformance.com/home/...ckets-bolt-in/
35olds
October 16th, 2016 12:57 PM
