cutlass/442
Guest
Posts: n/a
cutlass/442
Got a 70 cutlss I'm doing for a guy and making it a 442
Has 14" stock rally style wheels with the 5 spoke and chrome/ss trim rings
putting disc brakes all around
We need to get some 15" stock wheels of the same style
Can anyone tell me if the 15x7 stock rally wheel will clear the calipers?
thanks in advance
Rick
thanks in advance
Rick
Hi Rick
The 14"X7" should clear the calipers which is the size they used in 1970. Are these the 5 spoke that are the same color as the car? Or are these the 5 narrow chrome spokes with a black background similar to the Magnum 500 wheels or Chevelle SS wheels? John
Whoops! I just read your message again about rear discs. I don't know what size wheels you would need to clear that. Are you using Cadillac discs or aftermarket?
thanks in advance
Rick
thanks in advance
Rick
Didn't the B-bodies in the 70s offer disc brakes with SS wheels? I think these are 15 x 8 though. I know I have a set of them in storage, I just don't know what bolt pattern they are. Oldsguy also has a set in his garage. There was a time when I was in college that we were scouring slavage yards for SS wheels. We had a set on his 69 Delta for awhile. It sure looked good with SS rims but we had to use bolt pattern adapters. BAD IDEA! At least for anything other than a trailer queen.
Second, the late 70s B-body cars that offered the SSIII rims (such as the 1977 Delta 88 Indy Pace Car) used the A-body 5 x 4.75" bolt pattern and the same 10.75" rotor diameter as the A-body cars. The 12" B-body rotors (actually 11.75") were used on the wagons and HD suspensions (police and taxi) and had a 5 x 5" bolt circle. SSII/III rims were NEVER made in the larger bolt circle.
If you are using the 10.75" disks, the SSIII rims will fit. If you are using the 11.75" disks (B-body wagon spindles with 1LE Camaro rotors) the SSIII will NOT fit.
