W-27 rear axle
I agree that if the whole pumpkin is aluminum its a real W27 rear end. At least I've never heard of anything else that looks like it. There should be casting numbers in the aluminum, you can post them here for others to verify. I know of at least two members here who have these in their cars. They can speak up if you need help identifying something on it.
Or are you asking if there's a way to know if it came factory in your car? If so, you'd need a build sheet that shows what options were put on the car on the assembly line. If you need more details on that let us know. John
May want to read this also:
http://www.realoldspower.com/phpBB2/...887b6bfc4e0300
Re the ROP post, I'm the one that gave Brian the note re the 351 produced through June,'70. With only 6 in the month of June, a reasonable guess for the year would be a total of 355 units. In '71, 159 W27s (meaning just the covers) made it on to production cars.
SV 3:23 (20% of 355 or 71 units)
SX 3:42 (40% of 355 or 142 units)
SZ 3:91 (40% of 355 or 142 units)
If that "M12" in the third picture is stamped into the housing, it is probably the assembly date and decodes as November 12 (probably 1969, unless they were still assembling spares for the parts counters in 1970).
The cast iron housings had a 1- to 3-digit date code cast in them. The aluminum housing might, too? If so, it should predate the assembly date.
Forgot to mention mine is a 3:91. I have owned a few other w-27s including a 3:23 and a NOS unit without gears and axle stamping. So you can mark me down for three of the lot.........Lee
mine has a 0529 stamped on it. Does anyone know what that means. The car was built in February of 1970 and delivered in March. I would think the stamp would be the number produced or the stamp means something else.........Lee
The '70 W27 cover was a 12 hole cover. Was the accessory W27 diff cover (pt. no. 231026) a direct replacement 12-hole cover or was the over-the-counter part a 10-hole cover? Were there two different covers available over the counter for '70?
SV 3:23 (5% of 355)
SX 3:42 (30% of 355)
SZ 3:91 (65% of 355)
I have two w31's with w27's, one has no date code on the housing, and other is "A15". Both of my units are 3.91 SZ code. I don't think they made very many runs of the w27 unit. If we could get the date codes together, we could figure out how many runs there were.
IIRC, the 10-hole W27 cover version was never offered by Oldsmobile thru the dealerships. This 10-hole cover is just an aftermarket thing, like the W27 cover that is currently being made for Chevy 12 bolt rears.
I guess I got caught sleeping in class
#32
Yes. Definitely.
Don't know what you mean by an "over-the-counter, accessory W27-style".
The parts books will show 2 different part numbers for the '70 and '71 W27 covers. The '70 will have 12 holes and fit the O-type, and the '71 will have 10 holes and will fit the corporate 10 bolt.
#33
So, let me see if I have this straight. In 1970 you could order option #712/RPO W27 and you got a H.D., 10-bolt, 8 1/2" ring gear, rear axle assembly featuring an Al center section with a cast Al cover, designed with 12 attaching bolts. In addition, you could order the same diff cover separately, through the dealer's parts department, as accessory part #231026, to either replace a damaged W27 cover or to bolt onto a regular 12-bolt cover "O" diff, replacing its OE stamped steel unit. This "W27" cover would also fit late-'67, '68 and '69 "O" differentials.
For 1971 a customer could order #682/RPO W27, as a factory-installed option, which was comprised of just the cast Al differential cover, this year in a 10-hole version. The same cover could also be ordered over the parts counter as a dealer-sold accessory.
The only question I still have (on this subject) is, what is the accessory part number for the '71 cover?
#34
By over-the-counter I mean an item that was ordered from the dealer's parts department and received "over-the-counter," as an accessory, as opposed to receiving an item that was installed by the factory, in part or whole, as an RPO.
#36
Did the W-27 cover, in '70 & '71, have special bolts? Were they black oxide or stainless steel?
Factory W-27 installation for '71 was low due to factory strike and no mention of it in the brochures.
Unless the dealer mentioned it, the buyer had no way of knowing about the W-27 cover. Was probably best back then for the buyer to review the Order Sheet themselves, so as to know what was offered for the model they were buying - as the dealer surely did not tell them.
#37
I drove/parted out this W-30 and it had a W-27 complete rear end in it, 3:42s. I put it in a 71 Cutlass S and drove it as a daily drive for 3 years then sold the car. Then the 71 S was flipped in a ditch and last time I saw the rear it was under a 68 GTO with a 454 Big block Chevy with two 4s sticking out the hood and thats been close to 10 years ago.
Let me clarify, The car had a complete W-27 rear but That doesn't mean it was the factory one.
I do know the car sat in a cow pasture starting in 1983 and I brought it home in the mid 90s. The rear had to be put in before 83.
#38
#40
My brother bought a brand new 442 in February 1971, and the salesman did not mention anything about the W-27 rear axle cover, nor any other performance options. My brother only had the '71 sales brochure to go by, which hardly mentioned any performance options, and what was listed in the high performance brochure in 1970. Fortunately, he did his homework before placing the order with the dealer.
It really wasn't that obscure. It was listed in the SPECS booklet, which was every salesman's bible. There was no reason *not* to mention it any more than any other option. 1971 performance advertising was toned down from 1970 and unlike in '70, *none* of the individual performance goodies were featured in brochures.
