W30 camshaft specs.
W30 camshaft specs.
Anyone know what the camshaft specs. are for a factory 1970 W30 with automatic transmission ? I think I have a car that has been "over cammed", can't get it to idle in gear without stalling. I saw an older post here from someone who had the same problem. Does anyone recommend a suitable factory type replacement ? My car has no power brakes and a 3.91 gear. Thanks.
1970 W-30s with A/T got the same cam as the Toro W-34, P/N 400165, 57 deg overlap, 285/287 duration, .472/.472 lift. Without power brakes or A/C, you SHOULD have no problems with a more aggressive cam (including the "real" 328/328 W-30 cam), especially with that rear axle. Of course, M/T W-30s that year got the special Qjet that didn't have primary metering rods.
Sounds like what my high compression 403 did. Refused to idle, it was either 1500 rpm, or else it would drop off, vacuum signal dropped off, idle got worse, vacuum got worse, stall.
I ended up correcting it with manifold vacuum to the distributor. Adjusted initial, mechanical limits, and VA limit to suit. After that, the vacuum stayed high even at a nice low idle around 800 RPM.
Think about it, ALL the carb's functions depend on a vacuum signal, so if your vacuum signal fails, it all goes downhill, like a vicious cycle.
It can't possibly hurt to try full vacuum to the distributor. The overheating stopped, the seat of the pants dyno said "much better" and the idle was [and still is] fine.
PS your post was entered at 4:42 pm!
Thanks for the reply. I'm not too sure what you mean by "full vacuum to the distributor".
I had a 1970 442 W-30 with an automatic that had a 328/328 duration 475/475 lift cam from a 4 speed W-30 and had to idle it so high so that it wouldn’t stall in gear it bypassed the idle circuit I believe it was called, in order to idle it down and not have it stall we drilled a 1/8” hole in each primary throttle plate in the bottom of the carburetor so it could suck more air at idle.
It was late last night when I joined, I didn’t even think to look at a post date. I am new to this and I am darn near computer illiterate, I have no idea what I am doing on how to navigate this site. Thank You for letting me know about being too late, I usually am! 😃
Staying on-topic: That must've been some kind of cam in your engine if you had to resort to bleed holes just to get it to idle. My brother used a 328 W-30 cam in one of his cars once and didn't have to resort to that. Don't know why there was a difference.
Everybody does it. We just laugh at ourselves. It's okay -- just don't let it happen again!
If you do as Joe suggests (use a degree wheel and a dial indicator), you will get better accuracy if you use cam values at 0.050" lift instead of trying to interpret running duration (at 0.000" lift).
Here are the specs at 0.050" lift for the two W-30 factory cams:
1970 W-30 A/T (pn 400165): intake duration 223°, exhaust duration 223°
1970 W-30 M/T (pn 402569): intake duration 244°, exhaust duration 244°
