Carb to fuel pump line
I was jumping my roommates car today and i noticed that the carb was leaking gas from where i have my rubber hose (due to a crappy hose clamp. So when i swapped out the clamp i noticed that the end going into the carb seemed to be leaking a little bit too. So i tightened it some and then I really noticed a problem... the fuel line was turning easier than before ><. I went online to go buy a new from carb to fuel pump line and noticed there are at least 2 different kinds. Does anyone know what line to buy for my engine?
I love using the Right detail company, as i used them for my brake system and they lined up 99% perfectly. My fuel pump is one of those 3 outlet ones and it goes to a 455.
You should stay away from rubber hoses between the fuel pump and the carb. Use metal tubing to avoid catching your car on fire because a rubber hose split or melted.
Try this web site:
http://inlinetube.com/Preformed%20Li...s/ocatalog.htm
Try this web site:
Some of the fuel pumps used a 45 or 90 degree brass fitting and the fuel to carb line is bent. Either for a 180 90 or 45 degree...i think i bought mine years back from fusicks with for my 45 degree fitting i can check.....i still had to bend it a little i think
Sicky, give Danny a call. If your carb is leaking from the inlet, then, it can be helicoiled with a stainless steel insert. If you need that line just let me know.
Well i know i am definitely going to need that line, mine is half rubber right now lol. PM me for price with shipping to 78245.
Elephant_Engine_Ernie
October 10th, 2013 02:24 PM
mefirst72
February 10th, 2013 06:37 PM
stlbluesbrother
March 21st, 2011 03:24 PM
