70-72 Passenger Fender stick upward in back.
Old January 3rd, 2023, 03:57 PM
tkcutlass's Avatar
Does your 70-72 Passenger Fender stick upward in top back?
How did you compensate? thought it was just mine but It appears to be documented.
FWIW here's an entry from "The Good Olds Days"
Can anyone confirm or deny?
"All passenger side fenders DO NOT line up on the top back, they stick upward."
"This was a flaw in the mold that never got fixed."
Mine seems to have that flaw.
tkcutlass is online now
Old January 4th, 2023, 09:44 PM
tkcutlass's Avatar
Adding Pic
Old January 5th, 2023, 03:37 AM
Interesting, I never noticed it but I will look at mine a little closer. Never saw that book, Is it good?
Greg Rogers is offline
Old January 5th, 2023, 07:04 AM
Donaldbabineau's Avatar
Mine looks exactly like that, but it's aftermarket. I can't remember what the original looked like.
Donaldbabineau is offline
Old January 5th, 2023, 07:10 AM
Purveyor of Polyurethane
ijasond's Avatar
Originally Posted by tkcutlass
Adding Pic
Sometimes they've been damaged and repaired over the years, sometimes with ill-fitting aftermarket parts. Sometimes they just weren't that great from the factory. When doing restorations, you expect to have to do extensive work to gap them cleanly.
ijasond is offline
Old January 5th, 2023, 07:35 AM
tkcutlass's Avatar
My fenders are after-market.
Just curious if seems to be both original and after-market with the issue.
Some good info, not sure about the accuracy.
I'll get a pic of the driver's side later today.
Old January 5th, 2023, 09:30 AM
My original was aligned properly, but the NOS GM fender that I installed back in the 1990s sits too high just like that. My conclusion was the upper mounting bracket was welded on incorrectly, but I did not have the tools to cut the bracket off and re-weld it in the proper location. I always suspected that was the reason it was a replacement panel instead of being used on the production line - didn't pass QA so sent to the parts department and let a body shop deal with it.
Fun71 is offline
Old January 7th, 2023, 08:46 PM
tkcutlass's Avatar
The driver's side is much tighter.
Old January 8th, 2023, 03:54 AM
Tri-Carb's Avatar
Consider whether the sheet metal stamping die became progressively worm over the production run.
Tri-Carb is offline
Old January 8th, 2023, 08:42 AM
tkcutlass's Avatar
I would Imagine the same issue would apply to the driver's side as well.
Old January 8th, 2023, 08:45 AM
What does the bottom of the fender look like? You may need to add shims at the bottom to draw that down.
oldcutlass is online now
Old January 8th, 2023, 04:55 PM
tkcutlass's Avatar
The passenger side is loose on the bottom with no shims.
The driver's side has shims and is tightened.
Old January 8th, 2023, 05:20 PM
On mine, the drivers side had room for a shim or two under the bracket. The passengers side with no shims sat high. This indicated to me that the bracket was not welded in the correct location.
Fun71 is offline
Old January 9th, 2023, 03:43 PM
I would add some shims at the bottom and also shim up the core support on that side as the door gap is too wide at the top.
Old January 9th, 2023, 04:17 PM
72Cutlass S
gs72's Avatar
Mine is the same.
gs72 is offline
Old January 9th, 2023, 04:42 PM
tkcutlass's Avatar
Originally Posted by gs72
Mine is the same.
Is that an original fender/install?
How's the driver's side?
Old January 9th, 2023, 04:58 PM
72Cutlass S
gs72's Avatar
Left is fine. Not sure if it is original or not
gs72 is offline
Old January 9th, 2023, 05:07 PM
72Cutlass S
gs72's Avatar
Here is the left side
gs72 is offline
Old January 9th, 2023, 06:10 PM
Judging from mine I think this is the best explanation
Old January 9th, 2023, 06:36 PM
tkcutlass's Avatar
Which bracket are you referring to?
Old January 9th, 2023, 07:39 PM
The one at the top rear that sits on top of the firewall(?). It’s been since the 1990s so my memory of exactly where that bracket sits may be a bit off. From what I remember, there was a vertical mounting surface and also a horizontal mounting surface. The bracket was attached so that the horizontal surface was too high. The vertical had a hole that gave enough adjustment room.
edit:
I grabbed this pic from a video I found online. It’s a driver fender, but the horizontal flange at the very far left is the one that was too high.
Fun71 is offline
Old February 18th, 2023, 09:35 AM
tkcutlass's Avatar
I removed the bracket to see if I can get the passenger fender positioned better,
Seems better but still could come down a bit.
I am going to see if I can get it adjusted and the bracket welded back on.
Old February 18th, 2023, 10:04 AM
Andy's Avatar
My factory 70, never had the fender removed does show it sits up a bit higher.
Andy is offline
Old February 18th, 2023, 02:44 PM
tkcutlass's Avatar
Looks like repositioning the bracket that bolts in the door jam is going to work.
Old February 18th, 2023, 03:01 PM
Good job. So you made it better than factory original.
Fun71 is offline
Old February 18th, 2023, 05:00 PM
Gary
VC455's Avatar
Nicely done.
You have more skill than I and you asked the right people.
I tried adjustments to get my NOS fender to align, but couldn't get it right. When I sent the car for paining, the painter said he had to cut off a bracket and reweld it to get alignment correct.
When he told me that, I immediately thought the same as Kenneth...
VC455 is online now
Old February 18th, 2023, 06:05 PM
tkcutlass's Avatar
I got impatient when I took the bracket off, (The spot weld bit wasn't working fast enough)
I butchered the welds and ripped holes in the brace, so I had to fix them (kinda)
I traced the old position and the new, you can see my butchered holes and the trace marks.
You can see where there is no paint and about a quarter inch forward the trace mark for the new position.
I should have put something between the welding clamp and the fender surface, now I have a little body work to do.
I got the brace tacked in and test fitted again and got it pretty close to matching the driver's side.
Old February 19th, 2023, 05:01 PM
Stefano's Avatar
I have an NOS fender where that bracket is not welded in place and just safety wired to the fender. I have noticed this alignment issue prior and tried to adjust / align it out on one of my original paint cars to no avail.
Stefano is offline
Old February 19th, 2023, 05:29 PM
tkcutlass's Avatar
Spent some time tweaking the gaps now that the bracket is welded back in place.
Got it to closely match the driver's side.
There is a little crimp on the fender that needs attention at the seam.
Old February 19th, 2023, 06:07 PM
Trophyblue442's Avatar
Looking good!
Trophyblue442 is offline
Old February 21st, 2023, 07:04 AM
  #31
scrappie's Avatar
Sometimes you can get away with hogging out the hole to give you more adjustment. Like someone else said also, shimming the core support can sometimes make a difference. Now is the time to bang and cut metal if you have to before anything is painted. That gap at top of door is challenging, it can look great when closed but be sure to watch how close it get when the door swings open. Also dont forget about the door hinge adjustment, in and out and front to back can help sometimes also. Stay with it and you’ll get it.
scrappie is offline
Old May 13th, 2023, 04:34 AM
  #32
OLE442's Avatar
That's what I'm thinking. I've had trouble with my passenger side and added more shims to the bottom which pulled it down. Still, not perfect but very close! Fun stuff! LOL
OLE442 is offline
Old December 4th, 2023, 06:42 AM
  #33
ajr2820's Avatar
How far did you move the bracket? Hard to tell from the pics. I am having the same issue. It is not as pronounced, but I may give it a shot because it will bother me to no end. I got the drivers side perfect. The eyebrow on the drivers side was a mess though....still doesn't fit right.
ajr2820 is offline
Old December 4th, 2023, 08:29 PM
  #34
tkcutlass's Avatar
https://classicoldsmobile.com/forums...6/#post1480556
shows the trace marks for before and after.
it needs to be about 1/4" down and about 1/4" forward.
I recommend centering the bracket adjustment and tighten the bolt then clamp the fender to the bracket and drilling a couple of holes for the cleco clamps.
Once welded you should have plenty of adjustment to tweak.
Old December 5th, 2023, 04:30 AM
  #35
1Restorick's Avatar
My original paint 72 Cutlass does have a slightly wider gap at the top of the passenger fender. It's interesting that this was common as well.
Rick
1Restorick is offline
yorkman
September 21st, 2018 05:46 AM
70convert
November 20th, 2017 10:22 AM
firefighter5174
September 1st, 2015 03:12 PM
507OLDS
August 4th, 2011 12:23 PM
Fakser
November 8th, 2010 02:48 PM
Quick Reply: 70-72 Passenger Fender stick upward in back.
