Made some progress this morning...
Old January 5th, 2019, 08:20 AM
72455's Avatar
I got a chance to work on installing the rear bumper fillers before I head to work . It went relatively smooth and I'm happy with the results so far. I still need to close the gap between the bumper and the body, and I'm guessing that I have to do this with the bolts that hold the bumper onto the braces, am I right?
Here's a couple pics:
72455 is offline
Old January 5th, 2019, 09:44 AM
Yes Dave,
The gap you have is way out. You adjust this by loosening the bumper bracket itself, not the bumper. There are 2 slots in each brace that allow the bumper positioning. Here's what mine was before and after. It took about 35 minutes of adjusting to get it just right.
Stock bumper left side
stock bumper right side
test fit
test fit - note tape to protect paint
test fit
final fit
final fit
Allan R is offline
Old January 5th, 2019, 10:33 AM
72455's Avatar
Thanks Allan...that covers the gap on the ends...what about the gap between the bumper and the trunk lid?
72455 is offline
Old January 5th, 2019, 10:53 AM
I guess it's not as easy to see in the pictures. The gap between bumper and deck lid is a uniform 1/2" all the way across, including up over the tail lights.
Allan R is offline
Old January 5th, 2019, 01:38 PM
72455's Avatar
Before my final adjustment and after...
Before:
After .. much better now😀
72455 is offline
Old January 5th, 2019, 05:51 PM
You could still jam the sucker (bumper) up much higher until it is nearly hitting the corner of the body panel.
Vintage Chief is offline
Old January 5th, 2019, 05:55 PM
Old January 5th, 2019, 06:14 PM
72455's Avatar
I could, but I'm good with it just as is...😀
72455 is offline
Old January 5th, 2019, 06:21 PM
Dave- If you're fine that is all that matters!
Old January 5th, 2019, 06:23 PM
Let's face it, that bumper is going to shake & shimmy some when you go airborne over railroad crossing tracks & jump those parking lot speed bumps. So, a little wiggle room never hurts.
Old January 5th, 2019, 08:34 PM
72455's Avatar
Lol...I dunno what you've been doing with YOUR Cutlass, but maybe you should build a General Lee..haha
72455 is offline
Old January 6th, 2019, 10:29 AM
Ummm, Chief?? Your bumper could also benefit from being sucked closer to the quarter panels by about an inch or more. Dave has better tolerance on the extension side than you do. BUT, I have the best tolerances of all if you check out my pics. I have no more than 1/2" of gapping anywhere, and I used the proper locking washers to make sure that even on railway crossings or jumping the river my bumper won't move.
Allan R is offline
Old January 6th, 2019, 11:40 AM
72455's Avatar
Speaking of washers Allan, all of the washers that held the bumper onto the chassis braces were just plain flat washers. When I ordered my bumper fillers, I planned ahead and ordered 8 serrated washers and 4 sets of bolts and nuts. Good thing cuz I needed the washers, and the driver side chassis brace only had one bolt, so I was able to take care of that as well😀
72455 is offline
Old January 6th, 2019, 12:13 PM
Perfect! Now you have absolutely no worries of it coming apart like the wrecks of all the General Lee's destroyed in filming Dukes of Hazzard
Allan R is offline
Old January 6th, 2019, 12:48 PM
I enjoy living on the edge. LOL
Old January 6th, 2019, 12:51 PM
72455's Avatar
Lol..Allan, you are on a roll today my friend😀
72455 is offline
Old January 6th, 2019, 02:55 PM
A good friend of mine installed rear bumpers on the line as a young man at Oldsmobile in the early seventies. Every time he sees my car he reminisces by checking the bumper gap of my car. He used his thumb as a gauge to set them right, course everyone's thumbs are different...
Greg Rogers is offline
Old January 6th, 2019, 03:13 PM
But, Allan's thumb's a perfect.
Old January 6th, 2019, 03:35 PM
Lansing built
1970cs's Avatar
I like Allans gap, just appeals to my eye! And the rest of the car looks great too!
@72455 I admire the way you ask a questions before you do. It cuts down on the mistakes. Keep up the good work.
Pat
1970cs is offline
Old January 6th, 2019, 04:42 PM
Ah, that brings back memories of the last time my car went airborne over a railroad track back in the 80s. A friend was driving one night with 7 people in the car, saw the tracks while doing 45 MPH and hollered "Hold on!" at the last moment. I remember putting my hands up and pushing on the roof to brace myself and my head still hit the roof. Saw a buncha sparks following us down the road for a bit, later found out the bottoms of the header tubes were flattened and the custom drain plug in the transmission pan was bent. Other than that, no real damage and the rear bumper survived just fine.
Fun71 is online now
Old January 6th, 2019, 05:36 PM
hahahaha, nope. I used a tape measure to ensure perfect gaps. Bazinga!
Allan R is offline
Old January 6th, 2019, 05:48 PM
I botched the R&R of my oil pan gasket and now I’m looking at an imperfect rear bumper alignment? 2019 is starting off this way? This is seriously cutting into time spent walking the golf course.
Old January 6th, 2019, 07:47 PM
I'm sure a 3 wood or a short iron will fix the bumper for ya bud! What can I say? Someone before you adjusted or replaced the bumper on your car because that would not have left the factory like that.
Allan R is offline
Old January 8th, 2019, 03:48 PM
OCD
Old January 8th, 2019, 03:57 PM
I'm so proud of ya bud!! BUT, to match the body lines more perfectly the bumper should come down about 3/4" so the contour of the quarter panel and inside edge of the bumper match up better. IMO it's much to high.
compare to Dave's finished look and you'll see what I mean.
OK, runnin and duckin for cover now.....
Allan R is offline
Old January 8th, 2019, 05:54 PM
72 Olds CS
RetroRanger's Avatar
haha gotta love Allans attention to detail.
if your bumper has been bumped once or twice you may have to accept a best compromise, thats how my bumper is, id post a pic but Allen would have me back in the garage straighten something else out .
RetroRanger is offline
Tyson Williams
February 6th, 2019 01:01 PM
72455
Body work
53
November 28th, 2018 08:24 PM
Gmcdually
November 24th, 2018 08:15 PM
bigdooly
March 9th, 2018 06:06 PM
oldsguybry
June 3rd, 2013 07:05 AM
Quick Reply: Made some progress this morning...
