Care and Appearance Washing, waxing, paint care products, etc.
1970 W30 engine detailing done
Old October 15th, 2021, 01:51 PM
Andy's Avatar
Pulled my engine bay apart without taking out the engine just to clean, detail and repaint..Thanks to Vader I now have the correct waterpump. Turned out pretty good. Took a while to paint bolts and all. I used VHT Satin black on the brackets, radiator top plate, front plate etc. I used oldsparts 455 blue on block, bolts and valve covers..Aluminum intake brake cleaner and soft steel wool cleaned it up nice.
Andy is online now
Old October 15th, 2021, 02:17 PM
Nice work.
oldcutlass is online now
Old October 15th, 2021, 02:44 PM
Olds Fanatic
69 Hurst's Avatar
Looks great!
69 Hurst is offline
Old October 15th, 2021, 02:48 PM
72 Olds CS
RetroRanger's Avatar
That does look good.
any before pics ?
Is that the correct toplate fan shroud set up for your car ?
I ask because i dont know?
RetroRanger is offline
Old October 15th, 2021, 03:50 PM
BackInTheGame's Avatar
Sexy!
BackInTheGame is offline
Old October 15th, 2021, 03:59 PM
Andy's Avatar
any before pics ?
Correct top plate.. 343 gear 4 speeds were not 4 core radiators.
Andy is online now
Old October 15th, 2021, 04:57 PM
Andy's Avatar
any before pics ?
before pic, yes, you have a sharp eye, this 3 core radiator top should not have a shroud. However it was added years and years ago, the mounted top shroud bolts are on the underside of the top plate without drilling through it. Works pretty darn good. It is a factory numbers matching shroud along with the correct numbers fan etc. I am the 5th owner, have talked to the original owner and second owner at length about the car.
Andy is online now
Old October 15th, 2021, 05:53 PM
fleming442's Avatar
Looking good
Pet peeve: tidy up your battery cables. I'd suggest Fusick or somewhere for a decent repro or check out https://www.batterycablesusa.com/?gc...RoClR4QAvD_BwE for some nice aftermarkets. If you do go aftermarket, step it up to 1/0 or 2awg. It'll be the cherry on top.
fleming442 is offline
Old October 15th, 2021, 05:59 PM
72 Olds CS
AH i see, good info I wasnt sure if the top plate shroud combo were from the factory thanks for letting us know
the after pics look even better when you see the before pic
joesw31
September 26th, 2021 04:47 AM
oldsbuff455
April 23rd, 2021 08:56 PM
1977442
September 20th, 2019 04:20 PM
Oldracerjones
July 25th, 2019 07:23 PM
w30hurstolds
December 25th, 2018 01:50 AM
Quick Reply: 1970 W30 engine detailing done
