Care and Appearance Washing, waxing, paint care products, etc.
Anyone else chase water after wash with compressed air?
Old July 31st, 2023, 07:23 PM
cfair's Avatar
Somewhere back along the way I started occasionally chasing water out from under the window trims on my ‘66 big Olds remembering that rust in the rear lower corners had to be repaired on my Starfire coupe 25 years ago.
Just washed the car and chased out a bunch of water which would have evaporated in a day or 2, but I was happy to chase it out and wipe it off.
Do any of the rest of you use your compressor to clean up the inside / outside of your cars? I’m just wondering if I’ve gone too far down the rabbit hole…
Not unhappy, just wondering out loud…
Cheers
cf
cfair is online now
Old July 31st, 2023, 07:37 PM
It's actually a good idea, but you don't need a lot of pressure. A leaf blower works well.
oldcutlass is offline
Cheers
cf
You might be siding towards anally retentive, but I don't see anything wrong in what you're doing & IMO I think what you're doing makes complete sense. Not many would go to that extreme, but anyone should know when water sits on metal it accelerates corrosion.
Vintage Chief is offline
Old July 31st, 2023, 07:45 PM
cfair's Avatar
Not trying to be freaky.
It’s more just that the compressor is sitting there in the garage for various tires (bike & car) and the swap meet blow gun is sitting there for cleaning so it’s sorta “why not?”
Kind of a detail-focused “when you have a hammer, everything is a nail”
Cf
cfair is online now
Old July 31st, 2023, 07:49 PM
Cf
As I said, I think it's a great idea. Metal does not like water. In particular, I'll mention this, the greatest point of corrosion is going to occur where two dissimilar metals are joined (think of ANY fastener which penetrates a piece of metal - two dissimilar adjoining metals in particular); and, of course, wherever the exists a weld point.
Old July 31st, 2023, 07:53 PM
66SportCoupe's Avatar
Been doing it to my 66 and 66 cars for 30 years. Makes s big difference in maintaining them.
66SportCoupe is offline
Old July 31st, 2023, 08:45 PM
Oldsdruid
rocketraider's Avatar
I use both compressed air and an ancient electric leaf blower. Usually the blower because I can sometimes finish the job before the 60 gallon compressor tank pumps up.
Doesn't hurt to aim the blower down the cowl vents either. They're designed to air flush the rocker panels when the car's moving but the more water and detritus you can flush out the less your car will rust.
rocketraider is offline
Old July 31st, 2023, 08:59 PM
Carlarena1's Avatar
I'm a mobile car detailer. I always use my compressor to dry out trims for multiple reasons. First of course is rust prevention, but also After a wash and wax, that pesky water droplet could run out from under the trim (especially if the car is moved) and leave a nice streak on your nice, shiny, fresh car! also some dirt and debris wont dislodge with water alone. You would be shocked at what can hide behind a piece of trim!
Carlarena1 is offline
Old August 1st, 2023, 03:56 AM
That's a good idea.
Olds64 is offline
Old August 1st, 2023, 07:43 AM
72Cutlass S
gs72's Avatar
I use one of these. Used to use it to dry my dirt bikes after a wash.
https://drycycle.com/
gs72 is offline
scrappie
February 8th, 2023 04:33 PM
olds 307 and 403
September 5th, 2022 02:09 PM
rktolds
October 24th, 2013 05:50 AM
rustyroger
Tech Editor's Desk
October 10th, 2013 06:49 PM
ithaca4me
September 23rd, 2010 03:01 PM
Quick Reply: Anyone else chase water after wash with compressed air?
