Care and Appearance Washing, waxing, paint care products, etc.
Master Cylinder cast iron appearance
Old October 24th, 2019, 04:05 PM
mclark68442's Avatar
Seeking recommendations to keep a new Power Brake Master Cylinder cast iron finish from rusting and looking fresh. Its already installed on the car so I'm not looking at cast iron spray paint. I've seen brush on CI grey, but only in quart cans. A good wipe down with WD-40?
Thanks.
mclark68442 is offline
Old October 24th, 2019, 05:05 PM
72455's Avatar
Yup...that's what I did . WD40
72455 is offline
Old October 25th, 2019, 06:51 AM
Run to Rund's Avatar
I use satin clear from a spray can. Just be careful not to get brake fluid on the "paint."
Run to Rund is offline
Old October 25th, 2019, 08:36 AM
I've heard that this stuff works great, haven't used it yet though:
https://www.amazon.com/MACs-Auto-Parts-28-76556-Manifold/dp/B071FCCJT6/ref=sr_1_1?crid=1UDYCUMBUPLU0&keywords=calyx+manifold+dressing&qid=1572017643&sprefix=calyx+mani%2Caps%2C152&sr=8-1 https://www.amazon.com/MACs-Auto-Parts-28-76556-Manifold/dp/B071FCCJT6/ref=sr_1_1?crid=1UDYCUMBUPLU0&keywords=calyx+manifold+dressing&qid=1572017643&sprefix=calyx+mani%2Caps%2C152&sr=8-1
Olds64 is offline
Old October 25th, 2019, 09:26 AM
MI68442W30's Avatar
WD40 does absolutely nothing to protect it,a better choice would have been brake caliper paint,cosmoline, boeshield even oil is better !
MI68442W30 is offline
Old October 25th, 2019, 12:55 PM
D. Yaros's Avatar
I would use varnish, applied with a brush. The varnish should have a satin finish.
D. Yaros is offline
Old October 25th, 2019, 02:03 PM
Dave26's Avatar
I did what was done in post #3, about 5 years ago.....still looks like new.....FYI, I had the master cylinder off of the car when I sprayed it with the clear. As stated, brake fluid will eat the clear.
Dave26 is offline
Old July 4th, 2020, 05:07 AM
Olds Specialist LOL
JOHNNYOLDS442's Avatar
Wow looks great
UOTE=72455;1205361]Yup...that's what I did . WD40
[/QUOTE]
JOHNNYOLDS442 is offline
Old July 4th, 2020, 06:33 AM
I've been using the Eastwood master cylinder paint. It's a little too metallic, so it doesn't really look like bare cast iron, but it does stand up to brake fluid.
joe_padavano is offline
Old July 4th, 2020, 06:47 AM
That's good to know. I've tried several over past years and none worked. I always hear good things about Eastwood products. I might give this one a try.
Vintage Chief is offline
Old July 4th, 2020, 06:51 AM
Oh my...."...pure stainless steel pigment in an ultra durable epoxy ester resin..." I like that!
Old July 4th, 2020, 07:06 AM
72 Olds CS
RetroRanger's Avatar
I used the eastwood too. I sprayed it on the car. I used tinfoil around the brakelines and masked off the rest. It came out decent, and still looks good 3 yrs later. I cleared the booster. The master cyl was rusty looking like 72s before picture.
RetroRanger is offline
Old July 4th, 2020, 07:09 AM
I used the eastwood too. I sprayed it on the car. I used tinfoil around the brakelines and masked off the rest. It came out decent, and still looks good 3 yrs later. I cleared the booster. It was rusty looking like 72s before picture.
That looks excellent. Nice work. That's after three years? Sweet. Thanks for the image.
Old July 4th, 2020, 08:48 AM
I like Seymour Paint Cast Blast.
oldcutlass is offline
chip-powell
August 3rd, 2015 01:35 PM
Lively72 olds cutlass 442
May 7th, 2015 07:52 PM
glidrguy
Brakes/Hydraulic Systems
August 4th, 2014 09:49 AM
Mr Shifty Sidney
June 12th, 2013 12:06 AM
68conv455
September 16th, 2008 10:49 AM
Quick Reply: Master Cylinder cast iron appearance
