Lower ball joint trouble
I'm installing a lower ball joint. I pressed it in, it it goes as usual. It then pops and gets loose, now it will not stay in place. The other side no problem but it seems loose. I triple checked the part number.. I don't notice a crack or anything unusual in the control arm. What could be the problem? How can I fix it
What is the part number, is it a Moog problem solver ball joint? If it is a problem solver, you can tack weld it in place or replace the whole control arm. The spindle prevents the ball joint from coming out of the arm. It is a common problem for an old car.
^^^THIS!
I've done this in a few cases. The lower ball joint is in tension once the spring is in place, so it isn't going to fall out. A couple of tack welds between the ball joint housing and the LCA makes sure there will never be an issue.
