71 Cutlass Supreme Seat Restoration
Old January 22nd, 2010, 06:56 PM
  #41
hamm36's Avatar
That is a super job!!! The front is the hard one, the back will be a cake walk.
Do you have the plastic peaces that cover the arm rest mounting brackets? I had to make one for my seat. Keep posting, tips and ticks.
hamm36 is offline
Old January 22nd, 2010, 07:08 PM
  #42
GM Enthusiast
OLD SKL 69's Avatar
Thanks! I do have the plastic pieces that cover the arm rest. The rear seat still looked good but obviously compared to the front seat, it is not as soft and shiny, but then again, I am picky.
OLD SKL 69 is offline
Old January 22nd, 2010, 07:16 PM
  #43
GM Enthusiast
OLD SKL 69's Avatar
Since I had the seats out, I took the opportunity to clean up the floor. Some minor surface rust spots, otherwise the floor was mint:
IMG_0987.jpg?t=1264216179
I did not find the build sheet, but I did find this:
IMG_0989.jpg?t=1264216414
It was attached under the back seat.
Old January 22nd, 2010, 07:37 PM
  #44
vette442's Avatar
Hang onto it! On a Lansing-built car, that Fisher Body broadcast card is about as much build documentation as you're likely to find.
Terry
vette442 is offline
Old January 22nd, 2010, 07:47 PM
  #45
GM Enthusiast
OLD SKL 69's Avatar
Thanks Terry, yeah I looked everywhere except under the headliner and did find anything. I'm trying to find out what dealership it came from through the last owner, hopefully I can at least find that out.
Old January 22nd, 2010, 08:20 PM
  #46
we jeep inn's Avatar
Wow, nice. My floors are going to need some wire brushing and a coat of POR 15.
Didn't find any paperwork at all.
we jeep inn is offline
Old January 22nd, 2010, 08:24 PM
  #47
GM Enthusiast
OLD SKL 69's Avatar
Bottom's back in along with the rear seat. The picture makes the carpeting look a little aged but it's still in nice shape. Even date coded Feb 5, 1971 by Fraser products on a tag behind the carpet. I took a picture of it but it did not come out very well.
IMG_0990.jpg?t=1264220426
Old January 22nd, 2010, 08:35 PM
  #48
Eric Anderson's Avatar
That looks great, nice job
Eric Anderson is offline
Old January 22nd, 2010, 08:54 PM
  #49
Lady72nRob71's Avatar
Looking great! Nice find on the Fisher sheet.
I amost see you doing the back seat after they are both in, especially if you are picky! Floor looks great, too.
You are almost there!
Lady72nRob71 is offline
Old January 23rd, 2010, 05:08 PM
  #50
GM Enthusiast
OLD SKL 69's Avatar
Head Rests
The head rests in my Cutlass were adjustable as far as either all the way up or down, with no in-between. Here they are with the original locking location(for all the way up) from the factory:
IMG_0992.jpg?t=1264294427
This was way too high for me so I figured out what would be the right height, marked it on the headrest post, and cut another notch with my cutting wheel:
IMG_0993.jpg?t=1264294836
I also did the passenger side at the same location.
Old January 26th, 2010, 08:38 PM
  #51
hamm36's Avatar
another nice Idea..
hamm36 is offline
Old January 28th, 2010, 06:27 PM
  #52
GM Enthusiast
OLD SKL 69's Avatar
Here's the front seat back in the car:
IMG_0994.jpg?t=1264731681
IMG_0995.jpg?t=1264731809
IMG_0996.jpg?t=1264731867
Now I just need to get some nice "Oldsmobile" floor mats to finish it off.
Old January 28th, 2010, 06:37 PM
  #53
Looks swell - pat yourself on the back! You saved a good chunk o' cash, too.
I like the headrest mod - i need to do that also.
Fusick has some nice factory looking rubber mats in black. If they made them in Saddle, I would get some for my car.
Old January 28th, 2010, 06:51 PM
  #54
GM Enthusiast
OLD SKL 69's Avatar
Thanks Rob! I appreciate the comments.
Old January 29th, 2010, 08:19 AM
  #55
Darrell, Great Job. Could you post or PM me some pics of the cuts in the carpet for the front seat brackets. I chunked my old carpet and did not document how it was done. Lesson learned.
Old January 29th, 2010, 10:12 AM
  #56
My442's Avatar
I would dye the carpet. It would make a big difference.
My442 is offline
Old January 29th, 2010, 12:06 PM
  #57
When new, the seats were put in first and then the carpet went in by cutting a 'T' at each seat leg.
I circled the cuts in the picture below before I installed my bench seat last year.
I put my carpet in first, but still cut it like the factory did and made sure the carpet laid on top of the seat leg bolts when done.
Old January 31st, 2010, 04:11 PM
  #58
Perfect, Thanks Rob
Old May 15th, 2010, 01:24 PM
  #59
jaunty75's Avatar
Good thread. I wanted to clean the seatbelts in my '73 Custom Cruiser, which are also black, so I did a search and found this thread. I just cleaned mine of their 37 years of accumulated dirt and grim. Thank you.
jaunty75 is offline
Old May 16th, 2010, 06:36 PM
  #60
GM Enthusiast
OLD SKL 69's Avatar
No problem. Glad I could help!
Old January 16th, 2012, 10:25 AM
  #61
Tony72Cutlass'S''s Avatar
Hey Darrell,
Your seat looks great!
I see you have some pictures of the seat belt installation. Did you have to cut holes in the fabric or the holes were already there to thread the seatbelts through??
Any pictures of seat belt placement or the process would be great!
thanks,
Tony
Tony72Cutlass'S' is offline
Old January 16th, 2012, 07:23 PM
  #62
GM Enthusiast
OLD SKL 69's Avatar
Tony,
I will go back and see if I have any pictures of the seat belt placement. What I do remember was that I had to cut holes for the seat belt guides in the front seat. After the seat material was fully installed, I used the holes in the seat frame as my template for cutting. Basically I made an "x" with a x-acto knife and then inserted the seatbelt guide plastic sleeve in place.
Old January 16th, 2012, 07:33 PM
  #63
Tony,
Darrell,
Great! Thanks for checking! If you do come across a picture just post it here since i'm subscribed to your thread.
I'm a little bit nervous about cutting up my vinyl to insert the plastic piece...
-Tony
Old January 28th, 2012, 05:59 PM
  #64
Chumley's Avatar
Did you install new upholstery on the back seat bottom? I'm having a problem figuring out how the cover attaches to the back side of the frame. My hog ring pliers don't seem to be big enough for the oval holes that are supposed to be used for attaching. These are the only holes there, and after an hour and a half of trying to figure it out I had to take a sanity break. Do you have any pictures of this step? Thanks, Chumley
Chumley is offline
Old January 29th, 2012, 07:09 PM
  #65
GM Enthusiast
OLD SKL 69's Avatar
Chumley,
Sorry to hear that you are having trouble with that part. I have not done the back seat yet, although I plan on it. It is in great shape, but it is no where near as soft as the front seat. Do you have any pictures of the problem area?
Old January 30th, 2012, 03:39 PM
  #66
Here's a couple of "befores" I dug up from when covered the seats in my '72. Hope these help.
Del70
July 21st, 2020 11:42 AM
mydadscutlass
July 16th, 2012 08:41 PM
Mike77
August 3rd, 2011 05:25 PM
mrsgadgit
Site Help
April 7th, 2011 06:38 AM
theoldsrocket
January 17th, 2011 05:21 AM
Quick Reply: 71 Cutlass Supreme Seat Restoration
