antenna replacement
Old March 5th, 2024, 09:37 AM
ej69's Avatar
antenna replacement
1969 cutlass s convertible
my antenna broke off while driving and id like to replace..i believe it had a ball tipped end. where can i get correct replacement
thanks eric
ej69 is offline
Old March 5th, 2024, 10:06 AM
acavagnaro's Avatar
Ball tipped end isn't a 'correct replacement'. The proper antenna for a '69 is the arrow tipped antenna whose body is somewhat flat (ellipse shaped) rather than round. It's a very unique part. It's reproduced but pricey. If you're looking for 'correct', that's it. You can put a much cheaper and easier to acquire generic antenna on the car and most people would never know the difference.
acavagnaro is offline
Old March 5th, 2024, 10:45 AM
Did the whip just break off? If so, you should still have an antenna mount on the fender connected to a coaxial cable that goes to your radio. All you'd have to do is replace the antenna whip. Whether there was damage to the antenna mount or not you'll have to find a replacement from a parts car, or from Fusick if you want to use OE parts.
https://www.fusickautomotiveproducts.com/
Olds64 is offline
Old March 5th, 2024, 05:10 PM
CH3NO2 LEARN IT BURN IT
droldsmorland's Avatar
Front fender manual mast or rear quarter power mast?
droldsmorland is offline
Old March 5th, 2024, 06:05 PM
ej69's Avatar
Front fender
since it had a balm top it must have been replaced already
ej69 is offline
Old March 5th, 2024, 08:57 PM
As mentioned Fusicks has an accurate 68 GTO reproduction which is visually similar to a 68 Olds, pn 402253. The main mast is a touch shorter than the Olds, Its overall length is shorter when fully extended as well. When its on the car only an expert will notice. (This was true 7 years ago. Call them they may have improved it, though it is a nice repro).
Another option is to source used OEM. I do see used antennas pop up now & then.
Place a want ad here and look at the classified section. I know someone had a few for sale a while back.
Aftermarket will take you directly toward chineasium junk.
Old March 6th, 2024, 07:57 PM
BackInTheGame's Avatar
EJ,
User BeenThere has what you need, at a great price. See this thread.
BackInTheGame is offline
Old March 12th, 2024, 04:56 PM
ej69's Avatar
How does the antenna fit into base - how is it secured. Again this is 69 cutlass convert front fender. It doesn’t appear to thread in or have a lock nut. Does the antenna just push into base that has coax cable
thanks
ej69 is offline
Old March 12th, 2024, 06:32 PM
ej69's Avatar
Also is the antenna fixed or telescoping
ej69 is offline
Old March 12th, 2024, 06:39 PM
Old March 12th, 2024, 06:51 PM
3 Piece telescopic. Pic complements of BeenThere.
Old March 12th, 2024, 06:58 PM
Give ros6872 an email. He may have the entire base assembly.
Fusick has a 3 piece very accurate reproduction of the antenna and several other parts.
Antenna part number 402253
ros6872
Old March 13th, 2024, 05:41 AM
ej69's Avatar
Thanks for pics now it makes sense
ej69 is offline
Old March 13th, 2024, 09:41 AM
69455's Avatar
Is there such a thing a antenna in windshield for 69 ?
69455 is offline
Old March 13th, 2024, 11:18 AM
Not in the 1969 A bodies.
1969442W30
May 20th, 2023 05:42 AM
RROLDSX
August 30th, 2014 10:07 AM
501Paratrooper
January 30th, 2014 07:10 PM
Delta88conv455
August 24th, 2013 02:51 PM
4-Speed
August 23rd, 2010 05:52 PM
Quick Reply: antenna replacement
