Disc brake conversion kit
Recommendations on front disc conversion kits? Not concerned about re-using the 14" wheels. Other recommendations of new parts to install while the front end is apart? Many thanks in advance ...
which car?
I have used the kit from get disc brakes , what year is your car? Are you doing just the fronts? I am asking a lot of questions , because guys here can probably figure out how you can swap over to a stock set up , I switched to 4 wheel on my 69 and modified the installation so it looks more stock.
What year/model of car are you working on?
Here's a thread I really like that discusses swapping front drum to disc brakes on a 1964-72
https://classicoldsmobile.com/forums...sk-brakes.html
Eddie, you beat me by a minute!
I am in the process of installing 4 wheel disc brakes on my 72 cutlass... I am using the right stuff kits... I find the pre bent tubes need work to fit where the original brake lines fit.... If I had to do it again I would look into a different kit. The rears did not fit the SS1 wheels from specialty wheel. Had to turn down the rear axle flanges to clear the rotor, added a 3/8 spacer to push the wheel out to clear the caliper. 15 x 7 wheels. Took so long to modify the rear, have yet to get to the front! Might want to do an original parts swap. Seems to work fine even with 14" SSII wheels.
I had to turn down the axles slightly on my 69 4 disc conversion, but it was a casting seam, I did not like the way the kit did the lines for the rear, and as the front kit has the spring armour on it it will not fit like original, I ended up using the adjustable prop valve and the stock drum distribution block, there is more in my resto thread in the major builds
Yeah, to get rid of the spacers in the back, I am machining 2 rotors out of front rotors, and will need to space the calipers inward about 9/16 of an inch. this will require thinner pads (the rotor is .045 thicker than the one that come for the back...) This will give a lot of clearance for the calipers. Best of luck with your install!
The Right stuff ones that I purchased for the rear rubbed on the inside weld of the 15 x 7's (Outbd casting angled surface). I doubt they would work with 14's because there is very little radial clearance to the calipers... I might just throw my 14 SS2's on to see what happens before I install the rear. The 14 SS2's with the original disc set up on the front had plenty of clearance.
interesting???
After the 4th shim installation, I realized none were required to center the caliper on the rotor... (I can just turn the axles by hand) I also called them to verify... That is when I found out from them that I did not have an incorrect setup, "just 5%" of them need to have the axles turned down... My buddy fortunately had a lathe big enough... once I got it all together, I tried the wheel and there was the interference! Just want to let others know what they are up against with this "bolt on" mod!
I just checked a 14"iinch "steelie" and a 14 inch SS2.... No Go on the rear discs even with a 3/8 spacer ring... The SS2 are disc brake wheels, the 14" steelie" no idea... it was the spare so it might be for a disc brake...
This kind of got a little off topic ...
Could someone take a look at this and let me know what they think?
http://www.ebay.com/itm/1968-1972-ch...a6520a&vxp=mtr
Also looked at Summit Racing, they seem a little pricey.
http://www.summitracing.com/parts/su...utlass-supreme
Check out www.scarebird.com
here ya go...
have a look here as well, Joe P posted a pretty good thread, hope it helps
here is a spindle kit
http://www.performanceonline.com/196...E-KIT-DBS6472/
calipers from rock auto
http://www.rockauto.com/catalog/x,ca...liper%2BPiston
brake pads rock auto
etc etc just a thought...
full disc conversion kits
In that thread he states:
Would be interested in which one of these complete kits folks think are of high quality (for those who might not want to patchwork put the whole thing together).
Looking to do a conversion of all 4 to disk in the future. Currently the front are factory disk and the rears are drum.
"There are a number of high dollar disk brake conversion kits for the 64-72 A-body cars. These kits are very complete"
ddd777 what rear do you have? what diameter axle flange? year looks like 71-72 from the grill pics. Do you want to do fronts first and backs later? What wheels do you plan to use? steel or stainless lines? Eddie Hansen and I have been through it recently and let you know what our experiences are and how to get around problems... there are many others that can help as well. You might want to start a new thread with the answers to above questions and go from there....
Disc Brake Conversion - Complete Kits
- not sure about the rear (whatever was original??? but i will check)
- not sure about diameter axle flange (whatever was original???)
- '72 CS Convertible
- i would like to do them all at once.
- currently have 14/6 original wheels (with hubcaps) - may want to move up to 15/7 Rally in the future
- assume steel (to keep it more like original) any big reason for stainless?
have seen stuff like this:
have also had folks say good things about Willwood
many thanks in advance for any wisdom that either of you can impart, after having done it.
Not a bad setup for normal use. Should make repeated short and straight stops if the system is in good order and using modern radials. I would not bother unless going for a serious upgrade to bigger rotors / wheels along more of the resto-mod route.
And to the original poster, previous owner of my car put the Inline Tube kit on the fronts. Fits and works great but squeak a little and create a fair bit of brake dust. Not a big deal but swapping out the pads is on my winter to-do list.
Mine is a 72 CS convertible. Had front disc and rear drum. Went to 4 wheel discs (in process right now!) the rotors in the rear required the axle flanges to be turned down to about 6" to clear. (I put in a rebuilt posi rear, but the axles were identical to the original) The clip on the driver side just behind the rear lower control arm mount is a pain to get out, If you lift the body off to replace the body mounts, that would be a good time to install the clip! I used the right stuff (get disc brakes.com) kit. if you order from them talk to Todd McClure! I would not go with the system sold all over ebay! the routing of the lines to the front brakes come too close to the exhaust manifold flange. Get the OEM style Power Disc lines if using their PV72 proportioning valve. Eddie used the drum brake distribution block and a separate valve for the rear... in that case use the power drum brake lines for the front. The SSI 15" wheels from specialty wheel do not play well with the rear disc set up. I had to use a 3/8 spacer between the rotor and the wheel... (I am also working on a different set up for that....) Hope this helps you!
Dane I personally liked the get disc brake kit overall , I had 4 wheel power drums and I also wanted a stock look , as dave said there are some minor issues, but there are work around as dave mentions
Police Brakes
It has been recommended to me that I consider the Police Brake upgrades, instead of upgrading discs all around.
J55 Heavy Duty Brakes (Police Usage) (1968-1972)
There is a little discussion of the specs over here:
https://classicoldsmobile.com/forums...um-brakes.html.
Is this just about the rear drums, or is there also some sort of upgrade on the front discs?
Any thoughts on comparing what looks like beefing up the brake system vs. "modernizing" it?
disc conversion kit
Guys:
I bought mine from OPGI, everything came as advertised. The price was over $500.00 so I got free shipping, I had to pay the oversize thing though, freight was less than $40.00 from California. I got mine for around $600-$650 on sale, less than $700.00 delivered to my door. Everythging was nice and new/ clean, made you want to get right to work, NO problems w/ install either. I also did the complete front suspension makeover, you might as well , you already have it apart and w/ what are going to be spending to do it right, it is just a drop in the bucket! This was NOT a commercial for them, rather to say if you watch for specials and Sales, as Wife would say " Are you still on that thing?" That is how you find the Good stuff and Good deals though. End result is a much nicer finished product for less money.
Thanks Ron
Thanks Ron
#32
I found a kit on eBay called and found it was a kit from Right Stuff Detailing it was for 495.
Ended up paying 644 shipped
With slotted/drilled rotors and powder coated calipers and steel breaded line to caliper this included booster /master and spindles backing plates everything to install except hard brake lines
Have read great reviews so will let you know once installed
Mocephus
October 1st, 2021 09:45 AM
1971viking
October 9th, 2018 04:23 PM
