Do I Need An Ignition System
Old February 28th, 2011, 08:29 PM
plee3 64Olds's Avatar
It take my car a long time to start. I say around the 5th or 6th try it will fire right up. I know Im getting fuel, there is an electronic fuel pump hooked up. I have a 64 Cutlass with a 76 Cutlass engine. I was wondering if I got an MSD ignition, would that help my starting situation??
plee3 64Olds is offline
Old March 1st, 2011, 01:13 AM
Wasted's Avatar
I don't think the Msd will solve it. I'm guesiing it's your choke needs to be set up properly. Dose it start the first time when it's warmed up?
Wasted is offline
Old March 1st, 2011, 12:09 PM
I am going to say yes! it starts up after 1-2 times when it is warm.
Old March 2nd, 2011, 03:54 PM
64Rocket's Avatar
You need to adjust or repair your choke assy.
Gene
64Rocket is offline
Old March 7th, 2011, 09:24 PM
Gene
Ok, I think you are correct. I checked the carb before I started the car and all butterflies were open. (I’m pretty sure that the butterflies need to be closed so the car will start. please correct me if I’m wrong) I closed the butterflies by moving the choke assembly next to the throttle cable. (Bare with me! LOL! I think I’m explaining this correctly, If not, please correct me) Every time I step on the pedal (move the throttle cable) the choke assembly falls and the butterflies open. I looked on the left side of the carb (facing the front). I noticed that there is a tab with a hole in it. I look like there is suppose to be a spring there. Is this true?? If so, where do I put the other end of the spring?? BTW, I finally drove the 64 today! WOW! This thing hauls ***!! Seat pinning action! The tires screech at a standstill! This is my first real Hot Rod that I've been tinkering with and things are paying off. I just have stupid issues like this choke situation. I enclosed some pics so you would have a visual on what I’ve been trying to explain. Please leave any and all feedback.
Old March 8th, 2011, 03:37 AM
Looks like your choke's not connected.
I know NOTHING about Weber carbs for American cars (Porsches are another story...), so I can't say how it would normally be hooked up. Frankly, I had no idea they even MADE them for American cars.
I'd probably install a manual choke cable and call it a day.
MDchanic is offline
Old March 8th, 2011, 06:03 AM
stan 65 cutlass's Avatar
choke cable is missing, second to last pic you see the clamp and the hole in the end of the arm. should be all you need
stan 65 cutlass is offline
Old March 8th, 2011, 06:27 AM
Your edelbrock carb is a manual choke model as stated above just purchase a choke cable kit, install and your on your way.
oldcutlass is online now
Old March 8th, 2011, 06:33 AM
Registered
Bluevista's Avatar
x3
Pretty good reason for the choke not to be working.
Bluevista is offline
Old March 8th, 2011, 06:57 AM
Excellent information gentlemen!!!!! I understand! You guys are pretty awesome! I really appreciate all of the responses! I’m just a gear head that have a pretty decent toy to play with this summer. I’m pretty good with working on cars. I just don’t know the details like this that would cause me problems. I hope that I can get this at a local Parts Store. 1 more issue I have noticed, it takes an awful long time for me to shift out of 1st gear. I done some research and read that I need to hook a vacuum line from the carb to a transmission module. Is this correct?? Would this solve the long shifting time?? If so, where exactly is the trams module located?? I know where to hook the vacuum up to the carb, just not aware of any trans modulator.
Old March 8th, 2011, 07:21 AM
Originally Posted by plee3 64Olds
...it takes an awful long time for me to shift out of 1st gear. I done some research and read that I need to hook a vacuum line from the carb to a transmission module. Is this correct?? Would this solve the long shifting time?? If so, where exactly is the trams module located?? I know where to hook the vacuum up to the carb, just not aware of any trans modulator.
The vacuum modulator is the thing circled in red.
It looks like this:
(assuming a TH350 trans with your 350 motor in a '64)
MDchanic is offline
Old March 8th, 2011, 07:33 AM
TripDeuces's Avatar
A vacuum leak can cause the trans to hold in gear also if it's connected to that vacuum modulator on the trans. Many vacuum lines could be connected there so you'll have to check them all.
That is a manual choke Carter (Edelbrock now). If you had an automatic choke, either hot air or electric it would have been attached to the carb at those three mounting tabs on the passenger side.
TripDeuces is offline
Old March 8th, 2011, 07:57 AM
It looks like this:
Yes you are correct, it is a TH 350 trans. I will look for it today! Im glad I know what side it is on.
Old March 8th, 2011, 08:02 AM
Oh, one question, where is that vacuum line going from the back of the carb. I also notice, and I guess that Weber has a Carter/Edelbrock knock off?
Old March 8th, 2011, 08:57 AM
That hose that is in the back of the carb is going to the brake booster.
Old March 8th, 2011, 09:17 AM
Where is your PCV connected?
Old March 8th, 2011, 09:48 AM
TripDeuces's Avatar
This explains the Carter, Edelbrock, Weber connection.
'Carter AFB's were produced as the Carter Performance Series carbs until 1998. They are currently available as Edelbrock AFB carbs, which are produced by Weber USA. Most parts, including tuning parts like the jets and metering rods are interchangeable between the original Carter AFB's and the currently produced Edelbrock carbs.'
http://www.carbkitsource.com/carbs/t...AVS-index.html
What you have is a Carter AFB basically. Although a later version made by Weber who now makes them for Edelbrock.
Old March 8th, 2011, 10:41 AM
Interesting! So I have a Carter, (original manufacturer) Edelbrock, (the distributor) Weber (the new manufacturer who makes them for Edelbrock to sell) carb. Would I be correct in my wording??
Old March 8th, 2011, 10:42 AM
Im not for sure. I will check this evening.
Old March 8th, 2011, 10:46 AM
TripDeuces's Avatar
Yes that is correct Plee3
Old March 8th, 2011, 11:07 AM
I cant wait to get back home to tinker some more! I stayed up till 1:30am playing with this toy! LOL! I was going to call off from work but decided to come in. (I got to make the money to make this car right! No work, no pay or play)
Old March 8th, 2011, 09:21 PM
I installed the manual choke cable this evening and hooked up the vacuum line from the carb to the trans modulator. BIG DIFFERANCE! Started at the 2nd try! I also took it for a drive and it shifted in all gears! The car drives well. I still have a ways to go. When I’m cruising and floor it, it will not downshift. Is there anything else missing??
Old March 9th, 2011, 03:48 AM
Destructor's Avatar
Those AFB's are fun to rebuild, straight foward.
Destructor is offline
Old March 9th, 2011, 04:02 AM
Is the throttle kickdown linkage in place?
MDchanic is offline
Old March 9th, 2011, 06:34 AM
I am unaware of what a "kickdown linkage" is. I am going to say no. All I have is the throttle cable going to the carb. On the pics above, where would a kickdown linkage be placed?? How does the kickdown cable change the gears inside the trans??
Old March 9th, 2011, 10:15 AM
It is a cable or rigid hollow rod that runs from your throttle lever to a spot on the transmission that tells it when you floor the pedal.
MDchanic is offline
Old March 9th, 2011, 10:24 AM
Excellent information! Last question, where does it connect to on the trans??
Old March 9th, 2011, 10:32 AM
Oldsmaniac's Avatar
What trans is this? The 2 speed jetaway had electric kickdown if I remeber correctly. The turbo 350 used a cable.
Oldsmaniac is offline
Old March 9th, 2011, 12:12 PM
He said it was a TH350, but, now that you mention it, it is a '64, and we haven't seen any pictures...
MDchanic is offline
Old March 9th, 2011, 01:40 PM
yes it is a '76 TH350 with a 350 engine. Here are some pics of the new beast.
As you can see, I still have a ways to go. I would like to clean the wires up in the engine bay That is my specialty. Im an Electronic Maintenance Coordinator at the Museum of Science and Industry in Chicago. Ive been dealing with electronics since I was a kid! Getting the engine running to its potential is a challange to me. I seen a kickdown cable kit at Pepboys last night. would that be sufficient?? Where on the tranny do I hook the cable up to?
Old March 9th, 2011, 01:59 PM
  #31
I see you have the rare "dual column / floor shifter" feature...
I can't say exactly how to hook up a kickdown cable or rod - one of those "I know it when I see it" things, but it should be on the Left side.
I'm sure others can wax poetic on this one.
MDchanic is offline
Old March 19th, 2011, 06:32 PM
  #32
Wasted's Avatar
Here is a thread that has a picture to what it hooks up to. Its on the passenger side under the cooling lines.
https://classicoldsmobile.com/forums...7655-what.html
Wasted is offline
67442nut
December 27th, 2016 02:08 PM
joesw31
July 11th, 2015 03:40 PM
WendellB
May 28th, 2015 02:00 PM
Tim305
June 13th, 2014 05:08 PM
atkinsom
November 21st, 2011 09:40 AM
Quick Reply: Do I Need An Ignition System
