remove and install new trunk lock
1. Open trunk
2. Unscrew retainer plate
3. Pull retainer plate out as far as it goes
4. Slide lock cylinder out of trunklid
5. Transfer actuator rod to new lock cylinder
6. Replace gasket on lock cylinder if needed
7. Reverse steps to reinstall
Hi! Nice with more swedes here! There is two screws holding the plate, remove them and just pull it out, if it's the same on the 70' as the 69'?
This might help you MATTIA. Explore the site that is linked below for tons more info about your car.
http://wildaboutcarsonline.com/membe...E_MANUAL_8.pdf
Friction is holding it back. The plate is actually part of a curved spring steel clip that holds the lock cylinder in place. The spring force keeps the lock cylinder up against the trunk lid and this friction is what's holding that plate in place. Pull harder. I usually need to pry under the plate to get it to start moving.
I just replaced mine, and experienced the same issue you are having. I wasn't able to pull it out, so I took a 1/2 inch chisel (or you could use a flat head screw driver) and a mallet, and lightly tapped on the lower lip. Once I was able to get it to move a bit, I just continued to tap side to side and it came out. Just be patient and it will come out.
goldie442
August 21st, 2015 11:01 AM
g77rvd
April 12th, 2011 07:21 AM
KRICHEN922
July 1st, 2010 09:17 AM
Kidcutty
June 13th, 2010 07:12 AM
