1955 Olds
Old November 8th, 2006, 05:27 PM
and1stp's Avatar
1955 Olds
Just looking for some leads.
Have a "55 Olds, 324, 4bbl. Sat for about 10 years. Got it running. Rebuilt Carb, fuel pump. New plugs, cap, roter, wires etc. Gas is coming from 2 gallon gas can feeding to the carb/fuel pump. Has 95G's on od/meter. When I start it, 2 pumps, she starts right up. Point gap is where it should be 25-33 with no bounce. I then went to check timing, which is where it should be. My idle needs to be at 850rpm. While watching the meter/tach, it was bouncing around/not steady. Also, I have a back fire coming from the exhaust once its at temp. Any thoughts why Tach is not steady or why I have this back fire from the exhaust?
Thanks,
and1stp/John
and1stp is offline
Old November 8th, 2006, 06:01 PM
ozoneblue's Avatar
Wink 55 olds
Re check the specs on your point gap If I rember It should be closer 18.00 22 00 make shure dist. shaft is not loose . I recently got a 54 Rocket 88 same engine Went through same process .sounds like we both need new gas tanks. send some pics of yours . ozoneblue2004@yahoo.com
ozoneblue is offline
Old November 9th, 2006, 03:39 AM
and1stp's Avatar
Will double check specs thanks. Ya, removed the tank, was pretty bad inside and out. Gas lines were not o pretty as well. I'm going to buy one through TANKS, looks to be very close to size and filler neck is where it should be.
I have several pics but I'm thinking the only way to show them is through email.
John(and1stp)
and1stp is offline
dahl1car
July 21st, 2017 07:47 AM
American Lead
January 5th, 2007 01:40 PM
<emanusa1>
September 20th, 2006 04:45 AM
Tedd Thompson
June 26th, 2006 10:21 AM
bbock
June 5th, 2006 11:50 AM
Quick Reply: 1955 Olds
