'63 Super 88 - Rebuild a NIB Fuel Pump?
Trying to resurrect my 63 super. Hasn't run in about 20 years. Debugging the fuel system and hit the fuel pump. Mine has the sight glass/filter next to the pump.
Talked with "Then and Now" - $35 for a gasket set to use with new gas. Going to get that on order. Going through the car I found a brand new in the box spare fuel pump. Looking at the age of the pump I can't imagine it is set up for new fuel. Any way to tell?
Talked with the guy at "Then and Now" - he recommended rebuilding it and putting on the shelf for a spare. Any thoughts?
I would change out the valves for sure. They are not that hard to come out. I held mine in my hand, and hit them out with a socket. Change all rubber type parts while it's open. Operate the main diaphram a few times as you tighten the cover. I hope your kit comes with the diaphram and pull/push rod already assembled. Some kits make you reuse the old pull rod. Not fun.
70Post
August 15th, 2012 09:24 AM
