84 Delta 88 Windshield Wiper Issue
Old June 25th, 2017, 09:23 PM
Wauktown847
Wauktown847's Avatar
Nice to find a olds site. Anyways, I've got the 84 delta 88. Put all new (3) hoses for windshield wiper fluid to go to wipers. The wipers go when I activate wash on handle, but no fluid. I can't say for sure I even hear it. Help?
Wauktown847 is offline
Old June 26th, 2017, 06:27 AM
Rocketowner's Avatar
You need to have someone to try to activate the pump while you are close enough to hear whether the pump is pumping. The parts are available ,both the pump, and the kit to rebuild it if the pump is working, and I'm sure there are "You Tube"videos on how to rebuild
it. The rubber parts dry out with age but are reasonably priced and simple to replace. Good luck ,and welcome to C.O. Larry
Rocketowner is offline
Old June 26th, 2017, 06:37 AM
Olds Fever
CRUZN 66's Avatar
X2... Check the pump and make sure it is functioning, disconnect the inlet hose to the pump and have someone cycle it while you check for suction at the pump...
CRUZN 66 is offline
Old June 26th, 2017, 10:04 AM
Also make sure the nozzle ends are not plugged up.
oldcutlass is online now
47 Convertible
July 1st, 2017 11:24 AM
sixtyfour
July 27th, 2013 06:05 AM
2blu442
January 3rd, 2010 05:28 PM
Oldskeeper
September 15th, 2008 06:59 PM
BaileyJD1
May 10th, 2008 03:33 AM
Quick Reply: 84 Delta 88 Windshield Wiper Issue
