Timing mark question 56 Olds
The timing mark is easily visible viewing it from the drivers side fender location. But, I'm running a mild cam, so I probably want 8-12 degrees of advance from what I've been reading. The olds has a pointer but no "degree plate" like some other cars, just a mark on the harmonic balancer. The question is when viewing the timing mark from the drivers side fender, if the timing mark appears above the pointer is the timing showing advance? Thanks, Chuck
