hoses hot, lever opens louver door, cabin cold.
Old November 26th, 2023, 09:34 AM
aronukmale's Avatar
Unhappy hoses hot, lever opens louver door, cabin cold.
1982 Oldsmobile Delta 88 Royal Bromham 4.3L gas. New water pump, hot top hose, back flushed heater core, both hoses hot,
removed the glove box, extra rush of air when the lever is pushed to the hot side, and top lever on the heater setting.
Air is cold.
Where to go from here?
aronukmale is offline
Old November 26th, 2023, 10:05 AM
Start by telling us if this is a manual A/C or Comfortron
joe_padavano is offline
Old November 26th, 2023, 11:37 AM
Sugar Bear's Avatar
If both hoses stay hot the heater core may be air bound or clogged. The supply should be hot/engine temp, the return cooler/warm.
Sugar Bear is offline
Old November 26th, 2023, 04:44 PM
aronukmale's Avatar
Manual a/c-lever must be moved on panel.
Old November 26th, 2023, 04:46 PM
aronukmale's Avatar
I was wondering if the top hoses and heater core hoses could just be hot from the engine itself?
I was able to put water into both pipes of the heater core-to flush.
Old November 28th, 2023, 06:14 AM
rfpowerdude's Avatar
Hot water control valve?
rfpowerdude is offline
Old November 29th, 2023, 03:54 AM
aronukmale's Avatar
Turns out water hose pressure was not enough. Visit to Larrys Radiator and high pressure hose flushed heater core and fixed it. Thanks Guys!!
mks
May 16th, 2022 11:58 AM
Niels67
March 16th, 2014 03:01 PM
Armando S Nortez
November 15th, 2013 08:43 PM
FinkD88
March 5th, 2013 09:35 AM
deltaroads
December 8th, 2010 02:48 PM
Quick Reply: hoses hot, lever opens louver door, cabin cold.
