95 Cutlass Supreme Conv. turn signal problem
Hello. THis is my first Olds and first posting on this webpage, any help is appreciated. I just bought the car and noticed that the turn signal is not working all the time. The headlights/taillights work, brake lights brighten when pedal pressed, headlight brights work when turn signal arm pulled. I noticed that when I test the hazzard lights is when the turn signal stopped working for both lf. and rt. turns. Additionally, this car's cruise control has not worked since I bought the car >1 month ago. I got out the book to find the fuses to check, but I don't think this is the problem since the turn signals have stopped and started working again (only to stop once I tried to test the hazzards). Does this sound like a turn switch that needs to be replaced? If so where is it located? THanks! Ryan
costpenn
June 24th, 2015 10:38 PM
rkk69olds
June 21st, 2014 04:11 PM
