Negative battery cable chassis wire
In the PIM, this drawing depicts where the negative battery cable chassis wire is supposed to terminate. However, I don't see a hole where it could be screwed down. Here is the PIM sheet:
Where in these pics is that hole? Am I blind? Completely possible in my advanced age.
Maybe the PIM is talking about a different hole?
The car is a 1970 Cutlass S originally with a 350/TH350.
Joe, I am talking about the short small gauge wire that is part of the assembly, not the heavy gauge wire that goes to the block.
I blacked it to show it better below:
And the actual cable with small gauge wire:
Where is the hole for the small gauge wire screw in the "side baffle"?
Hmmmm...anyways, it's a "seal". I don't see it sealing much in its current location/configuration. It appears to be nearly straight up & down (plumb) as depicted in the PIM. Re-examine location of that seal - I think it needs to be "sealing" something.
Sorry about that. I said Section 111 (which obviously doesn't exist) & should have said Section 11.
I think you're going to find that seal is not located as per the PIM but instead needs to be relocated to its correct position. Good Luck.
I wouldn't hang my hat on that statement. I'm somewhat familiar w/ the history of your car via threads since you joined CO. An original 350, swapped out for a 403 by your buddy then a transplant of a 455? Who knows exactly how that configuration took place? They remove the OEM radiator &/or shroud &/or side baffle? Plenty to hook back up in the correct or incorrect positions.
Yes, original 350 swapped for a 403 by my buddy. Then I got it. I doubt he did anything unnecessary and only did enough to swap the 403 in. I pulled the 403 and now I’m preparing for a 455. I’ll make it right regardless if it was like that originally or it somehow got changed sometime in the last 30 years.
Seriously, thanks a bunch for engaging with me all evening!
Did you see my post? https://classicoldsmobile.com/forums...1/#post1557682
v8al to the rescue! I looked under there for the first time and v8al is right. There it was, a lone screw doing nothing but awaiting the negative battery wire.
That’s it cleaned up and installed. Turns out that the radiator side seals are installed correctly from the factory as they match where the PIM says they go. Thanks v8al and everyone!
