Halo top replacement
I have 72 cutlass, with halo top, will I need to remove rear window to replace vinyl top? Old top was removed and roof is in great shape, so I want to put the top back on.
When I took the rear window trim off of my 71 98 I found that the rear window needed to be removed in order to properly repair the rust that started in the window channel.
My 71 98 never had a vinyl top and the body had little to no rust on it but the window channel did need a repair (as well as the passenger's side fender skirt). I sugget removing the window to prep the window channel for vinyl top replacement; otherwise, you might be doing it again in a few years.
Of course, as Olds64 points out, it is sadly not uncommon to find pinchweld rust under the urethane.
Oldssupreme
April 30th, 2016 05:48 PM
Oldssupreme
May 28th, 2013 05:35 PM
