Radiator & Fan recommendations
Hi all,
Looking for a radiator for my 72 442 convt, 350 / 4speed car with no A/C.
I am guessing the more cores the bettter, so looking at 3-4 core, but I am torn between Aluminum or Brass/Copper. Never tried aluminum, and they look to be alot cheaper.
Then there is the fan. I think the orig is a rigid 4-blade with no clutch ... do I run that, or upgrade to 7blade with clutch? Then of course there is electric ...
I have OE shroud .. planning to reinstall that for sure.
Any thoughts/recommendations/experiences you can share would be great.
Jim
Jim
I went with a cold case aluminum
I would think your decision would be based on what your end plan is. If it’s originality then that leaves out the aluminum , if you go to a four core brass and copper I believe you will need to change the saddles and upper plate , I believe the three core you’ll be fine if your car came with that fit wise , on the other hand if not concerned about originality as much , opens up your options , I installed a cold case radiator aluminum in my 69 with 455 , I used the 4 core saddles and top plate it fit perfectly , the cold case comes in manual and auto versions , I used radiator paint on the center section and the radiator looks stockish I also upgraded to the 7 blade fan and use the stock shroud , it looks the part , I have not driven it yet
If originality is important, then a copper/brass is your only option. If you can tolerate aftermarket, then definitely go that route. Cheaper, superior cooling abilities, all around win.
As for fans, if you go aftermarket radiator, use a 7 blade fan with a thermal clutch. Use a shroud.
I typicially like the stock appearance .. and no reason to believe it will overheat .. at least I hope not
However since I have nothing to start with, and the patient is wide open, I thought i might reach out to check other experiences. Aluminum does seem to be cheaper. Clutch fan seems to make sense as well ... cept I think I might need a different water pump & pully
Hayden offers fan clutches in different lengths. It might not be a bad idea to hit your local junkyards and get a couple used fans just for mock-up. If you can determine the length you need, no need for additional spacers.
At the minimum, use a 3 core. The difference on cost between a 2 and 3 core is minimal, the added cooling capsid worth the piece of mind.
I haven't compared prices for copper verses aluminum, but from what I have heard they are expensive. You could probably buy 2 aluminum for the cost of one copper.
Thanks for the suggestion on Hayden!!! Tough to find anything in any junkyards around here any more .. seems to be athing of the past!!
I am guesssing I will install the radiator .. then measure distance between pump and radiator .. and use just clutch or clutch and spacer
Jim
Jim
Alex72cutty
May 30th, 2014 03:20 PM
