Fan shroud and engine Decal
Hey guys,
I have a 1979 Hurst Olds and I need to replace the damaged fan shroud. I am not having any luck locating a replacement and was curious what other types will interchange.
I am also looking for what would be the correct decal code for the emission decal that goes on the fan shroud. I have OH and SP. Both show Olds 350 5.7 liter, but different timing (one is 18 and one is 20) Any idea which label is correct.
AFAIK, the 79 H/O had 2.73 gears except for california, that came with 2.56 gears. That SP emissions label is for 350R engines in cars equipped with GU1, aka 2.41 gears. 1979 A-body 350R did not have that gear ratio. Thus, the OH should be correct. The 79 H/O experts should be able to chime in here.
OH emission label part number would be 22501778.
Is the California emissions label version an "SR" code or still an OH code? I'm showing part number 22500538 as the 79 California Hurst/Olds label part number.
Chris Scott
September 14th, 2021 04:23 PM
