1953 - 98 defroster and blower control ?
Old February 7th, 2015, 07:18 AM
stocki26's Avatar
Hi
its me again, the crazy Austrian driving a '53 Olds 98
Actually I am trying to find the reason why the blower doesnt work, are there any well known weak points ?
When giving + directly it works, but it doesnt work or switch on or off or regulate when turning and pulling the **** "B" - seems the switch is ready to be thrown out.
But I dont know how to get it out, how to check it and so on ....
Anyone that can help me ?
Any pics of that part available ?
Thank you !
stocki26 is offline
Old February 8th, 2015, 08:37 AM
Ozzie's Avatar
Do more checking
You have found that the motor is good. So the problem probably is the switch, or the fuse, or the wiring. You can take a voltmeter or test light and trace through the circuit for the blower to find the loss of voltage. The switch will be the hardest to fix. You can check it with an ohm meter after it is disconnected from the circuit. I don't know of any typical weakness in the '53, but perhaps another member may. There probably are also some voltage dropping resistors inside the heater case. It may not help any, but the original part number on the switch was 3131128. It will interchange with the '51 S-88 and all of 1952 & 1953 according to the Olds parts book. The fuse for the blower in 1955 was 25 amp. I don't have the information for 1953.
Ozzie is offline
Old February 15th, 2015, 04:58 AM
stocki26's Avatar
still working on it .... just another question at the moment
is that switch original ? ......... I dont think so - but it looks really old also ;o)
stocki26 is offline
Old February 15th, 2015, 05:53 AM
Ozzie's Avatar
As I don't have a '53 I can't say for certain, but I am agreeing with you. It doesn't look like something the manufacturer would have used. Perhaps someone added it for a reason. If there are wires connected to it, trace the wires to find where they go. It could be for an added accessory, to replace the function of a defective factory switch or an anti-theft ignition "kill" switch.
Ozzie is offline
Old February 15th, 2015, 06:24 AM
Proud Viet Nam Veteran
redoldsman's Avatar
No, that is not an original switch. I notice a horn button on the right side of the steering column so somebody had done some rewiring. My 54 has the heater control and defroster cables right about where that toggle switch is. The blower switch is in with those controls. Does the **** to the right of the toggle switch control your defroster?
redoldsman is offline
Old February 15th, 2015, 07:23 AM
stocki26's Avatar
thank you guys
I will take out blower switch first, do some measuring and maybe some new wiring ...
Damn - I would have loved to keep it all as original as possible - seems that will not work on each part
It really hurts me to cut just one old textile covered cable and give a new one - am I crazy ? )
stocki26 is offline
Old February 15th, 2015, 05:42 PM
Ozzie's Avatar
thank you guys
No, you are not crazy. Many others feel the same way, and go to great efforts and expense to preserve originality.
Ozzie is offline
79MKII
March 3rd, 2016 05:29 AM
JOHNNYOLDS442
August 22nd, 2012 04:23 AM
Erinyes
May 5th, 2012 08:06 AM
Beob
March 5th, 2011 06:34 PM
eeibell
September 13th, 2007 05:04 PM
Quick Reply: 1953 - 98 defroster and blower control ?
