⁴g high idle cam
Old August 15th, 2015, 03:09 PM
m371961's Avatar
⁴g high idle cam
My high idle cam sticks and does not drop down with engine warm. Does it only rely on gravity to drop it? I have cleaned it, lightly sanded the side, tried it dry and with oil. Just touch it with throttle open and it drops. Any ideas?
m371961 is offline
Old August 15th, 2015, 04:44 PM
It works off the choke. Putting oil on it will make it worse because it will attract dust and dirt.
oldcutlass is online now
Old August 16th, 2015, 06:11 AM
m371961's Avatar
I know the choke linkage lifts the cam when it closes, then as the linkage drops, the cam should drop as the choke opens. So there is no spring or mechanical connection that moves it as the choke opens? I have tried it dry and oiled. I guess I will remove cam again, clean maybe try silicone spray.
m371961 is offline
Seff
September 20th, 2012 04:46 PM
dancutlass
August 21st, 2012 06:26 PM
73rocketship
July 6th, 2012 06:45 AM
75cutty455
July 8th, 2011 05:42 PM
87CUTTY
May 31st, 2007 02:33 PM
Quick Reply: ⁴g high idle cam
