Just scored a 1950 98 Futurmatic
Old April 19th, 2010, 08:09 PM
  #81
frmula505's Avatar
I got the car fixed. Turns out one the axles came loose Only 2 bolts without nuts were there when I took off the drum. Nice easy fix. Sat parked for a couple of weeks with such a small problem. Now time to start setting up the air suspension. Will post pics.
frmula505 is offline
Old August 26th, 2010, 08:36 AM
  #82
51NINETYEIGHT's Avatar
A noob bumping old threads!!!! So whatever happened with this car is it bagged now? Lets see em!
51NINETYEIGHT is offline
Old August 26th, 2010, 10:21 PM
  #83
425 super rocket
tindrumstoo's Avatar
bump for this thread, i want to bag mine so i want to see how this turns out, love the tires! and hubcaps!
tindrumstoo is offline
Old August 30th, 2010, 07:02 AM
  #84
frmula505's Avatar
Sorry I haven't posted lately, work has had me out of the country most of the summer. I still don't have it bagged. I was trying to figure how to set them up with the 6 volt system. i had already purchased a manual controller. I finally decided to change it over to 12 volts and eliminate the problem. I installed a one wire 12 volt alternator, bulbs, coil, solenoid, and drop down resistors for the meters and heater motor. It starts like a champ and is running better than ever. I had a bog problem at higher rpms. thought it was the fuel system (I rebuilt the carb and fuel pump). I was more of a weak spark problem. any ways I do have some under hood pictures I took.
high res shot click thumbnail to enlarge.
And here is a little something I am going to install soon.
Old August 30th, 2010, 07:05 AM
  #85
citcapp's Avatar
That tri-carb setup is sweet,and will look great under the hood the 303's and 324's have the best style points of any of the Olds engines.
citcapp is offline
Old August 30th, 2010, 07:16 AM
  #86
frmula505's Avatar
I love the stock valve covers on this engine. The guy I bought the intake from had some nice aluminum covers, But I kept the stockers instead.
Old August 30th, 2010, 07:18 AM
  #87
citcapp's Avatar
I would keep them as well. The chebby guys like them so much that an aftermarket copy is available for chebby small blocks to make them look like Olds engines. Highest form of compliment.
citcapp is offline
Old August 30th, 2010, 06:59 PM
  #88
Awesome, I started looking for dates on the posts and started to wonder if you might have sold it or what. Under the hood looks really good! Im glad to see you car from start to "finish". it gives me hope and sight for mine. Thanks for posting!
Old August 30th, 2010, 07:05 PM
  #89
Registered Abuser
Red Delta's Avatar
I like the stock carb look as well. My knowledge of cars of this vintage is limited. Is that a carter?
Red Delta is offline
Old August 30th, 2010, 07:15 PM
  #90
Yes so vintage in fact I couldnt afford to even rebuild my 303. Not if I wanted to keep the wife and house that is!
Old August 31st, 2010, 06:16 AM
  #91
frmula505's Avatar
It's a Rochester side draft. As you can see the air intake kind of sucks (or doesn't depend on how you look at it). The original oil bath air cleaner was around 4' wide. So you would get air from both sides of the engine. Well mine was long gone when I got the car. I will still hold on to the original setup.
Old August 31st, 2010, 07:11 AM
  #92
stlbluesbrother's Avatar
Outstanding thread - keep up the great work
stlbluesbrother is offline
Old August 31st, 2010, 06:41 PM
  #93
Cool just act like Im not here! lol
So on the 3carb set up does it use a aftermarket valley pan too?
Old September 1st, 2010, 04:16 AM
  #94
frmula505's Avatar
There is a finned aluminum valley pan available. But you have to modify oil ventilation system. I'm gonna see if I can use the original. Will keep you guys posted.
Old September 3rd, 2010, 07:40 AM
  #95
oldscruiser's Avatar
Hey guys sorry for off-topic but how much would a '50 Olds 98 2 door coupe in similar condition cost?
oldscruiser is offline
Old September 3rd, 2010, 07:52 AM
  #96
Land Yacht Captain
66ninetyeightls's Avatar
As much as someone is willing to pay!!! Sorry I couldn't resist.
66ninetyeightls is offline
Old September 7th, 2010, 12:48 PM
  #97
frmula505's Avatar
Drove the car to Alamosa CO for the Early Iron Rod run. here are a couple of shots.
Old October 14th, 2010, 04:37 PM
  #98
50olds98
bslook1213's Avatar
Nice job!
Beautiful job on the 98. I am currently in the middle of restoring my 50, 98 (same as yours) for the fourth time in 35 years. Looking through your progress photos has revived my enthusiasm to finish mine up. I would love to see more photos!
bslook1213 is offline
Old October 15th, 2010, 04:25 AM
  #99
frmula505's Avatar
Out of the country on work related travel (Cambodia). will take more when I return on the 20th.
Old June 1st, 2011, 06:13 PM
  #100
425 super rocket
bumping this old thread again, now i'm bagged! so i thought i'd share a picture for ya.
Old June 7th, 2011, 07:16 AM
  #101
frmula505's Avatar
Haven't got the bags on yet (too much work travel. Spain, and Malaysia in the last few months. While I was in Spain in Feb/Mar some *** popped a hole in my gas tank to steal gas.
Here is a video after I got it fixed. Sorry It's just the link, couldn't get the embedding to work.
http://www.vimeo.com/21238532
Old June 7th, 2011, 07:18 AM
  #102
citcapp's Avatar
Creeps are everywhere. Would love to catch one laying on his back under a car, man would he regret that position in short order
citcapp is offline
Old June 23rd, 2011, 03:02 PM
  #103
radioburningchrome's Avatar
I have a headlight switch for a 1950 oldsmobile if you are interested.
radioburningchrome is offline
Old June 23rd, 2011, 04:54 PM
  #104
frmula505's Avatar
Thanks I'll keep you in mind if my gives me problems.
Oldsguy
March 17th, 2010 12:11 PM
nukesec1
Wheels and Tires
February 21st, 2010 07:54 PM
Redog
July 2nd, 2009 10:28 AM
Dutch
Ninety-Eight
June 2nd, 2009 03:01 AM
1BAD68"S"
October 6th, 2006 03:25 PM
Quick Reply: Just scored a 1950 98 Futurmatic
