Transmission Rebuild Recommendations
Old February 22nd, 2024, 08:49 AM
Bigsk8r's Avatar
So after 53 years, the TH400 in the old girl has given out. As I do not yet have a large garage, cherry picker, or engine stand, I will need to locate a shop to do the work. Although it will be costly, I am thinking to have the following done and would appreciate any recommendations:
- Pull engine and transmission
- Rebuild transmission
- Replace pan gasket, rear main seal, and any other seals that are easily accessible with the engine out.
- Replace motor and transmission mounts
As a potential item that is easier now than later... get the left side dual exhaust manifold and go ahead with new, stainless dual exhasut. May not make that expense yet though...
Thanks!
Bigsk8r is offline
Old February 22nd, 2024, 08:57 AM
Sounds like a good plan. Where are you located?
You mentioned stainless exhaust, you won't be able to buy any kits for your car the way guys do for their Cutlass. I suggest you take the car to a local exhaust shop once the engine and transmission work is done and see what they can do. You can get exhaust manifolds out without lifting the engine. It's a PITA though.
Olds64 is offline
Old February 22nd, 2024, 09:05 AM
Bigsk8r's Avatar
Located in Austin area of Texas. Live in a Northern suburb called Leander. Asking around now for local recommendations.
Fortunately, when the blowout of the dipstick happend, my son limped it straight to my place and parked it in the cul-de-sac in front of our house. So, getting a tow truck to it, and getting it to a shop once one is selected will be the easy part.
Bigsk8r is offline
Old February 22nd, 2024, 05:26 PM
Roy Ale
307-5a's Avatar
I keep blowing out frost plugs , so could change all frost plugs and when transmission has been disconnected from engine , look for a frost plug at back of engine . There is one frost plug i did not change yet , it is too close to the dip stick tube , i could not get the dipstick tube out without breaking it so i still have at least one rusty frost plug that i can see .
307-5a is offline
Shawnk111
December 22nd, 2020 08:54 AM
Vintage Chief
January 19th, 2019 06:52 AM
dalilama
June 30th, 2016 11:37 AM
dmruschell
July 21st, 2015 03:42 PM
wolfman98
October 27th, 2009 07:37 AM
Quick Reply: Transmission Rebuild Recommendations
