wheel bolt pattern
Old August 29th, 2009, 08:57 PM
1973olds98's Avatar
wheel bolt pattern
anyone know the bolt pattern on a 73 olds 98,,i am looking for some custom wheels..
1973olds98 is offline
Old August 29th, 2009, 09:50 PM
2blu442's Avatar
It's a 5 on 5, 5 bolts at 5" inch spacing. Most full sized GM 1960's-70's probably newer are the same. I have a 1979 Chev 1/2 ton pickup, it has the same. John
2blu442 is offline
Old August 29th, 2009, 09:54 PM
1973olds98's Avatar
Hey thanks,,,,
Old August 31st, 2009, 06:45 AM
If you buy custom wheels make sure you post pics.
Olds64 is offline
Old August 31st, 2009, 08:32 AM
1973olds98's Avatar
i odnt know if i want to go with some 14x6 knock off wheels or put some 22's under it..The clearance factor is where i dont know where to start...They have to be able to clear the skirts..I tried a 14x7 100 spoke wire rim yesterday and it didnt fit..clearance issues with the fenderskirt...
Old August 31st, 2009, 09:12 AM
1973olds98's Avatar
Does anyone know the offset i would need for the skirts,,No way are am i rolling without them..The carlooks like a derby car without them,,,lol
Old August 31st, 2009, 09:13 AM
You have to get your backspacing right too. I'm not sure what the backspacing is on our stock wheels.
BTW, please don't put 22" wheels on your car. It makes a classics look so dumb. Plus, you will eat wheel bearings really fast and cause your car to brake even worse than it does.
Olds64 is offline
Old August 31st, 2009, 03:32 PM
Land Yacht Captain
66ninetyeightls's Avatar
All the info for stock wheels says the offset/backspace is 0.
66ninetyeightls is offline
Old August 31st, 2009, 05:20 PM
1973olds98's Avatar
Umm,,,,,22's on a classic slammed,,,I think looks awesome,,,,,But I havent decided....Its all about what fits really,,,And my car brakes really nice for a big old boat..
Old August 31st, 2009, 07:35 PM
2 '66 98's
bigoldscruiser's Avatar
What part of the country are you in?? I'm in New Jersey and I have a set of 17X8 Eagle 203 5on5 wheels with 235/55R17 Cooper Lifeliners (27.18"OD)with less than 10k miles on them. They fit on my '66 98 OK with no interference with skirts or on inside. I have $1450 invested. I will let them go for $600. if you or anyone else is interested. Bruce
bigoldscruiser is offline
Old September 1st, 2009, 06:01 AM
If you really want to put 22s on your car then that is cool. Keep us posted. Just make sure you check your brakes and wheel bearings often. You should also rotate the tires every chance you get. By having wheels that big on your car you will eat tires quicker than normal. Plus, tires are expensive when they are little rubber bands.
Olds64 is offline
Old September 21st, 2009, 05:23 PM
1973olds98's Avatar
I still have no updates on what size would work..I have a couple buddies that are going to let me borrow a rim to see what i am working with...
rollins
Wheels and Tires
August 11th, 2015 01:57 PM
bcf102
August 1st, 2013 06:09 AM
Nailhead 88
November 19th, 2008 08:21 AM
ss427
January 13th, 2008 08:57 AM
2 door cut
May 20th, 2007 11:34 AM
Quick Reply: wheel bolt pattern
