Non-Olds Engines For discussion on non-Oldsmobile engines. All forum rules apply.
1965 425 swap maybe ??
Old December 18th, 2023, 09:54 AM
GCH
GCH's Avatar
Hi , the engine in my Dynamic has low compression in cyl 5 so i figure what to do. Fully rebuild of this
engine is the same cost that the whole car . Maybe a check in the engine and hoping cylinder bore is
ok , engine starts easy , no noise , have oil pressure and no heating issues.
Have seen Oldsmobiles here with other engines and also diesel engines , i have read that all Olds 455
engines fit directly in my Dynamic but they are not so common here.
So i figure best way to go , of course i wish i could keep the 425 depending on rebuilding cost. But any
other engine suggestions for a easy swap who could fit transmission ?
GCH is offline
Old December 18th, 2023, 11:33 AM
Sugar Bear's Avatar
Put air in the cylinder and see where it leaks, through the carb/intake, out the exhaust and/or out of the breather. It could be a burned valve and/or stuck rings. If the rings are stuck try a chemical ring soak for a few days before a rebuild if you wish.
That is a big car, you'd probably be happier with a big block 425 or 455.
Sugar Bear is offline
Old December 18th, 2023, 11:56 AM
GCH
GCH's Avatar
I have tried air with both valves closed and the air
leaks down in the oilpan. Have tried some chemicals but it pooring down to the oilpan directly.
Have zero compression in cyl 5 .
yes a bigblock would be nice
GCH is offline
Old December 18th, 2023, 12:05 PM
Sugar Bear's Avatar
Then yes scoping it next is a good idea. You might get by with rings and/or a piston.
Old December 18th, 2023, 01:16 PM
OLDSter Ralph's Avatar
Originally Posted by sugar bear
then yes scoping it next is a good idea. You might get by with rings and/or a piston.
x 2
OLDSter Ralph is offline
Old December 19th, 2023, 06:49 AM
GCH
GCH's Avatar
That,s what i hope also but can not do anything with the car untill spring.
GCH is offline
1965Delta88okc
May 9th, 2019 08:43 AM
1974 Cutlass 442 455
December 4th, 2016 07:00 AM
braden1351
November 13th, 2016 01:06 PM
66Dynamic
May 14th, 2015 04:09 AM
Half Baked
December 29th, 2007 10:11 AM
Quick Reply: 1965 425 swap maybe ??
