Non-Olds Engines For discussion on non-Oldsmobile engines. All forum rules apply.
Doing a engine swap from a 231 V6 Buick Engine to a 350 V8 Pontiac engine
Old April 22nd, 2023, 04:59 PM
DJKillaC94's Avatar
Found a 350 Pontiac engine with a Buick TH350. I need advice on everything that I will need for this engine swap from a V6 231! Is this a direct fit or will I have to majorly modify anything?? Thanks homies 🙏🏾💯
P.S: this is my first ever engine swap too as well
DJKillaC94 is offline
Old April 22nd, 2023, 05:13 PM
Bfg
Bfg's Avatar
Do you know the make, model and year of the car your working on? Kind of important information to give before anyone can gives you advice.
Bfg is offline
Old April 22nd, 2023, 05:58 PM
66_Jetstar's Avatar
Nothing insurmountable.. the poncho will not bolt to the 231 frame pads. You'll need to source/fab mounts. Once that is done you'll have some wiring to take care of and normal swap stuff.
FYI a Buick 350 is a direct swap. They are pretty cheap and easy to find in the Buick world.
66_Jetstar is online now
Old April 22nd, 2023, 07:06 PM
Rocket Renegade!
How did you find out what car he's working on?
BangScreech4-4-2 is offline
Old April 22nd, 2023, 10:00 PM
DJKillaC94's Avatar
I have 1985 Cutlass Supreme
Old April 22nd, 2023, 10:04 PM
DJKillaC94's Avatar
I was trying to find a Buick 350 but no luck. Found a few 350 SBCs tho I was kinda leaning towards that but I looked at all of the modifying you may have to do
Old April 23rd, 2023, 04:23 AM
Bfg
Bfg's Avatar
Why not go with a 350 Olds motor?
Bfg is offline
Old April 23rd, 2023, 07:09 AM
DJKillaC94's Avatar
I couldn’t find one
Old April 23rd, 2023, 10:02 AM
Rocket Renegade!
Originally Posted by DJKillaC94
I couldn’t find one
My guess is it will be easier to find an Olds 350 than it will be to swap in a Pontiac.
Old April 23rd, 2023, 04:15 PM
Out of Line, Everytime😉
olds 307 and 403's Avatar
Yeah, the Buick 350 is a near direct swap. What year Pontiac 350? I believe the early motors won't work on the 301 mounts, which work best in a G body. I hate seeing sbc/ls in everything, a Pontiac V8 is at least something different.
olds 307 and 403 is online now
armbrbr
December 31st, 2021 02:43 PM
Reese Neis
September 10th, 2021 04:20 PM
toymobile
February 18th, 2016 08:12 PM
CUTTDAWG
May 25th, 2011 06:45 AM
slipbakka
March 18th, 2007 11:49 PM
Quick Reply: Doing a engine swap from a 231 V6 Buick Engine to a 350 V8 Pontiac engine
