Non-Olds Engines For discussion on non-Oldsmobile engines. All forum rules apply.
LS2/4L65e Swap
Old March 18th, 2022, 08:48 AM
ART T's Avatar
LS2/4L65e Swap
I am doing this swap in my 1964 Cutlass. I am putting everything in a new frame and then swapping the body. The 65e looks fatter than the 4L60's that I have used in the past. Am I going to have problems clearing the floor pan?
ART T is offline
Old March 20th, 2022, 04:11 PM
oddball's Avatar
Is the 64 floor pan the same (or at least similar) to the Chevelle? Might find some info from those guys. I think the pre-68 tunnels were smaller than later, right?
oddball is offline
Old March 20th, 2022, 05:19 PM
ART T's Avatar
Yes to both questions.
ART T is offline
Old March 28th, 2022, 01:15 PM
ART T's Avatar
Sitting on the mounts.
ART T is offline
Old March 28th, 2022, 01:21 PM
Loaded68W34's Avatar
what oil pan are you using? The mounts look good. The only issue you might have is with the inner tie rods hitting the oil pan. You should probably mock up the steering box, drag link, center link and inner tie rods before you go much further even if you don't assemble the rest of the suspension.
Loaded68W34 is online now
Old March 28th, 2022, 05:42 PM
ART T's Avatar
302-1 pan, I found the plates on ebay. The pedestals are 1965 Chevelle. I have the steering linkage from the donor car.
ART T is offline
Old April 24th, 2022, 02:23 PM
ART T's Avatar
ART T is offline
Old April 24th, 2022, 02:29 PM
ART T's Avatar
If I had my alternator bracket the engine would be wired. I cut the Fiteck harness and took out one hundred feet of wire. The tranny cleared with a small amount of hammer work, mostly for the dipstick. I am trying to make it to Tenn. in July.
ART T is offline
oldaman
January 25th, 2022 07:11 AM
Rallye469
November 18th, 2021 08:28 AM
oldsmoboogie
April 20th, 2021 10:01 AM
1951Super
June 12th, 2012 09:21 AM
1969442FREAK
February 20th, 2011 03:43 PM
Quick Reply: LS2/4L65e Swap
