1955-56 exhaust manifold questions
Digging in and pulling what is left of my exhaust, I found the studs were pretty much gone and one broke off. Any reasons I cannot just drill these out and put a long bolt through?
Secondly, what is this little flapper in my exhaust? What does it do?
Bolts can be removed with an EZ out, penetrating oil and a lot of patience. The flapper thing is the heat riser that helps the engine reach operating temperature. The one you have is frozen like mine. Remove and soak in penetrating oil for a few days and with luck it will free up. Check to see if the bi-metal spring is still attached to the other end. I am going to use an aviation penetrating oil called Mouse Milk to free mine up. Good luck
the flapper is free and isn't frozen up luckily. I do not see or feel the resistance of a bimetal spring. the flapper just flaps around without any resistance. Looks to me like about 10 horsepower if i remove it
atkinsom
May 29th, 2013 06:39 PM
1966 442
November 17th, 2012 12:49 PM
