'66 Lower ball joint clearance
Old March 23rd, 2024, 11:51 AM
ourkid2000's Avatar
Jeez, another engineering beauty on these things ('66 Toronado). The clearance from the CV boot to the lower ball joint is wafffer thin, to say the least. When you put in a service replacement lower joint, you have to use a nut to secure it as the original was riveted in. Well the clearance between the boot and the nut is even worse, obviously.
I took a carbide bit and shaved the nut down as far as I dared and even with that my cv boot clamp still hit the nut and pulled the clamp off when I moved the car out of the garage today. Previously, I had tested it out prior to moving the car while I had it on jacks. At the time It had sufficient clearance while suspended on thejacks and I turned the wheel and spun the tires a few times just to be sure. I noticed when on the ground, however, the clearances were tighter but still looked ok. Yeah, not so much. You can see the clamp hanging off in my picture below.
Anyone ever dealt with this? I was going to get a new nut and grind it down thinner. Not sure of any other way. There's a lock washer under the nut, maybe remove that and just rely on the loctite and stake?
Check out that clearance!
ourkid2000 is online now
Old March 23rd, 2024, 12:35 PM
Why not rivet it?
Fun71 is offline
Old March 23rd, 2024, 12:48 PM
ourkid2000's Avatar
Why not rivet it?
The ball joint comes with a threaded stud. It's part of the assembly so there's no other way to secure it other than using a nut. The CSM shows it this way as well so it's just the way it is.
Old March 23rd, 2024, 02:08 PM
Loaded68W34's Avatar
The problem might not be the clamp hitting the nut at all. When I restored my 68, I used outer CV boots like you have in your photo. I found that they did not have enough flex when turning the wheels and both sides popped off almost immediately. I switch to a convoluted style boot and have not had a problem since. Here is the best shot I have of the boots I switched to:
Also, how did you tighten the clamps? Do you have a tool like this (bottom one in pic), or did you just pull it tight with a pliers?
Loaded68W34 is online now
Old March 23rd, 2024, 02:47 PM
ourkid2000's Avatar
You could be right about that. I had moved the car out of the driveway and back in order to bring it in front on. When I turned into the driveway I had to go to full left lock. I wonder if I just popped it off?
Yeah, I used the tool in your second picture to secure the clamp
Old March 24th, 2024, 07:47 AM
ourkid2000's Avatar
Just wondering if you remember where you got that boot?
Old March 24th, 2024, 10:10 AM
I believe it was this one:
https://www.ebay.com/itm/29276787376...Bk9SR5zUgZfOYw
Old March 24th, 2024, 10:21 AM
ourkid2000's Avatar
Thanks for that! I love how they specifically leave out the '66 Toronado. Uggh, it never ends with this thing.
ourkid2000
June 21st, 2023 04:16 PM
Bigbassape
October 22nd, 2021 06:24 PM
joseph44
August 11th, 2018 01:57 PM
Arrowstorm
Suspension & Handling
28
November 7th, 2015 01:09 PM
defiant1
March 16th, 2015 09:44 AM
Quick Reply: '66 Lower ball joint clearance
