The saga continues
The saga continues
So as i expected the axles wont clear lower cont arm with no weight on it so i had to bust upper ball joints. Kinda glad i did. Did someone weld them in or torch cut tops off for axle clearance? Jus keeps getting better
I've got one that's in decent shape. But I'm in Oregon and the OP is in New York. I'll offer mine at a price I'd want to pay, which I consider on the low range but shipping may be more than the purchase price. If anyone closer has one in good shape go ahead and offer it to him.
Then so all can understand what happened to his, the factory riveted these on the sides of the ball joint and it looks like the bottom as well. Or the top, so it won't interfere with the axles.
Hopefully the replacement ball joint won't have a bolt head that would interfere with the axle. I would be cautious about turning down the axle to clear the ball joint fastener. I suspect there's other members here who've changed out the ball joints and may be able to provide some advice on how best to do it.
Straight from the 66' Toro CSM
